2005 6.0 icp pressure at idle - Ford Powerstroke Diesel Forum
post #1 of 12 Old 12-31-2012, 04:29 PM Thread Starter
What's normal?
I'm seein 1020 psi on my monitor at idle. That's with 190cc injectors, ad2 at 68psi, and xrace from Eric.
A buddy told me idle psi should be around 500~600 psi....
Truck runs great with no problems.
Blackcloud413 is offline
post #2 of 12 Old 12-31-2012, 04:31 PM
HarvestingInternationally's Avatar
Does ur buddy have stock injectors
http://img716.imageshack.us/img716/2580/oppt.jpg
2006
F250 Crew Cab Long Bed 6.0 TurboDiesel FX4
Diesel Site Coolant Filter, Edge Insight CTS, BPD FICM 48v, Metal CAC Tube, Blue Spring,Sinister Diesel EGR Delete w/ Up Pipe, Riff Raff Boots, MBRP 6212-409 Exhaust, BFG AT's,
Bilstein 5100's with Leveling Kit, ISSPRO EV2 Gauges (Pryo
, Fuel Pressure)
Eric
HarvestingInternationally is offline
post #3 of 12 Old 12-31-2012, 04:41 PM
Powerstroke Techie
Lilpooh's Avatar
Feedback Score: 3 reviews
That's almost double of what's normal!!
Sent from my iPhone using AutoGuide.com App
2004 F350 CC DRW King Ranch
X-3 tunes by DJ'S,QT,GH,ID. Gryphon FICM tunes, ARP studs,Stage 1turbo,ATS coolant recirc lines,Swamp's 48v ficm,coolant filter,AD2,Snow Perf stage II,EGR delete,4" turbo back straight pipe,S&Bintake,Quad "A" pillar autometer gauges,Suncoast Tri Disk Conv.,Billet input shaft,Suncoast superduty rebuild kit,Trans-go shift kit,Mag-Hytec trans pan,CFM+ elbow,ccv mod,15K reese 5er,17" LCD TV/DVD,Cobra 29 Nitewatch CB
Lilpooh is offline
post #4 of 12 Old 12-31-2012, 05:48 PM
IDWITHELD's Avatar
I'm 100% stock.
I think I see about 560 psi at 790 rpm
IDWITHELD is offline
post #5 of 12 Old 12-31-2012, 05:55 PM Thread Starter
Yes he does.
Why is mine so high?
post #6 of 12 Old 12-31-2012, 06:03 PM
Mine runs about 640-650 at idle after up to operating temp. On a cold start I will see almost 1000 for the first few min after high idle kicks in. Mine is on stock injectors and no tune.
Is this all the time or at initial start up?
2004 F250 6.0L CC SWB 4x4 (name's Eleanor)
Straight Piped, Coolant Filter, EGR Delete, Blue Spring'd, Amsoil'd, ELC'd, Rev-x'd, S&B Intake
JumpinJack is offline
post #7 of 12 Old 12-31-2012, 06:05 PM Thread Starter
I see 1020 psi after warm up. Cold start is about 1200 psi
post #8 of 12 Old 12-31-2012, 06:16 PM
snafu!'s Avatar
I'm guessing that isn't a full fuel tune, pulling fuel might have something to do with the high icp pressures.
Cameron
2006 F250 Lariat CCSB
Comp Turbo 64/88 compounds
Warren 285/100
ODAWG ported intake
R&R rods, mahle pistons, stage 2 colt cam
Built Trans
Water/Meth
snafu! is offline
post #9 of 12 Old 12-31-2012, 06:17 PM Thread Starter
Correct, not a full fuel tune.
post #10 of 12 Old 12-31-2012, 06:46 PM
Powerstroke Techie
Lilpooh's Avatar
What are you using for a monitor?
Lilpooh is offline
