Swapped From BPD 4 Phase 48v FICM to BPD 6 Phase 58v FICM! - Page 9 - Ford Powerstroke Diesel Forum
  #81 (permalink)
Old 01-16-2013, 06:43 PM
MAD - Modification Addict
Feedback Score: 7 reviews
Apparently not enough J-Rod. Cause now your rolling in a glorified Herbie the love bug.
  #82 (permalink)
Old 01-16-2013, 06:45 PM
BOSS LEVEL
That was the only bpd part it had. Everything else was fallig apart. But I put it on my sisters 6.0 so it's still in the family. Also told her husband he's not allowed to get rid of it lol.
It's a bit longer then the herbie
  #83 (permalink)
Old 01-16-2013, 07:34 PM
Chapter Director
Send a message via AIM to Fantom
Your sister has a truck and you're rolling in a chick-mobile? j/k
  #84 (permalink)
Old 01-17-2013, 01:52 AM
BOSS LEVEL
She has a 04 excursion lol.
  #85 (permalink)
Old 01-17-2013, 03:55 PM
Powerstroke Techie
Feedback Score: 3 reviews
I have used dielectric grease before and it is slightly thicker than the motorcraft electrical grease. The thinner grease allows you to cut a smaller hole for the nozzle and apply grease more precisely.
It also makes the tube easier to squeeze
  #86 (permalink)
Old 01-17-2013, 06:28 PM
gotcha.. might have to look into it
  #87 (permalink)
Old 01-24-2013, 08:28 PM
So to confirm if you clip the wire for 53v first then you can't ever run the 58v because once you cut both it defaults back to 48v? Then if you cut the 58v first you won't be able to ever use the 53v option? Just trying to figure out cuz mine is scheduled to show up tomorrow. thanks.
  #88 (permalink)
Old 01-25-2013, 02:28 AM
Yup, once you cut them, you're committed....unless you're really good at working with electrical in those tight little quarters and even then, I don't know what kind of affect on resistance you'd have by soldering them back, if you'd even have any.
  #89 (permalink)
Old 01-25-2013, 05:00 AM
IMO it would be easy to solder those wires back together, plenty of room. And I see no chance of any issues if its a good solder job.
  #90 (permalink)
Old 01-25-2013, 05:16 AM
Yup I have contemplated changing voltages
that jumper is insulated i believe so you would clean the ends at the cut and use some high temp solder ,,
