Whining noise in exhaust
I've been trying to track down an annoying whine/drone coming from the rear of my truck. I thought it was the diff, but I just figured out that it's coming from the exhaust and is almost certainly originating in the turbo. I can hear it at speeds anywhere from a crawl to about 45 MPH. It's not turbo whistle. It's a much lower frequency resonating drone that happens when the turbo is spooling up and down. It's loudest when under load but still does it a little when in park.
I tried power braking, and it does it just as loud as when you're driving, so it's definitely not something in the driveline that only makes noise when you're moving. Does anybody else's truck do this? It's getting louder, so I'm thinking the turbo bearings must be going. Also, my fuel economy seems to be getting worse. I know it will get worse on winter grade fuel, but they've been selling that here for at lease a few weeks, and my economy seems to get worse almost every day. |
I would be suspicious that the vanes are stuck in your turbo due to coking.Still under warranty???
Yep, I've got 60k left on the warranty. That makes sense because it's doing the turbo fart a lot more than it used to, and Marc mentioned sticking vanes could do that. It does it all the time when it's cold and a lot more frequently when it's warm too.
It sounds like it's time for a trip to the dealer. |
Yep...Marc I believe ,has a lot of hands on experience....good info there !
I do a lot of 6.0 research only. I think I would "suggest" to the dealer that if the turbo is sticking...maybe they will checkout /clean the egr also? |
I wouldn't take it to the dealership unless I really had too.. They'll want to look it over so you'll have to take all of your mods out. Unless your mates with the mechanics there and they won't care if you've got the mods..
If only you guys knew what some of them modifications really did to your motor and trans. I've seen some pretty sick **** happen due to modifications. Plus if ford suspects foul play they will deny your warranty coverage and they have ways to tell if there has ever been any programers or chips installed.
What's with the preaching? This problem has absolutely nothing to do with the programmer. I could hear the noise when I got the truck intermittently. It's just getting worse now. I run on econo 99% of the time anyway. The only thing that's changed on the truck is the flash, and that's easy enough to set back to stock, disconnect the batts to clear the KAM, and then drive a few days to put legit data back. I've never heard of anyone having problems with warranty as long as they don't admit to having a programmer.
sorry i wasn't saying that your programmer had any thing to do with your problem, i was replying to the guy who said not to take your truck into a dealer cause they would force you to take out your aftermarket addons.
i don't say nothing unless the customer turns into a jerk and tries to tell me that i don't know squat and then i never go anywhere other than to maybe the service manager, and he's got his own opinion.
