ECT-EOT ok? - Ford Powerstroke Diesel Forum
post #1 of 13 Old 12-26-2012, 10:25 AM Thread Starter
06SuperDuty's Avatar
ECT-EOT ok?
I've been running 70-80 mph for about 4 hours now unloaded. It's 63 outside. I'm seeing 184 ECT and 196 EOT. Is it time for a cooler again? I've got 51000 on this one.
Sent from my iPhone using AutoGuide.com Free App
Rob
SSgt, USMC
2006 CC SB True Blue,
MBRP 4" Turbo Back
Kitty Delete
SCT X3 Looney Tuned
Edge Insight CTS
Home Brew ZooDad
06SuperDuty is offline
post #2 of 13 Old 12-26-2012, 11:09 AM
HarvestingInternationally's Avatar
looks like ur thermostat is stuck open you should consider replacing it..do u have a coolant filter...ur ECT should be around 190 192
http://img716.imageshack.us/img716/2580/oppt.jpg
2006
F250 Crew Cab Long Bed 6.0 TurboDiesel FX4
Diesel Site Coolant Filter, Edge Insight CTS, BPD FICM 48v, Metal CAC Tube, Blue Spring,Sinister Diesel EGR Delete w/ Up Pipe, Riff Raff Boots, MBRP 6212-409 Exhaust, BFG AT's,
Bilstein 5100's with Leveling Kit, ISSPRO EV2 Gauges (Pryo
, Fuel Pressure)
Eric
HarvestingInternationally is offline
post #3 of 13 Old 12-26-2012, 11:11 AM
powerstroke_god's Avatar
Yes replace your thermostat
2006 Ford F350 Lariat
SCT with WPE tunes
MTW Hybrid turbo
EGR Delete
Coolant Filter
Edge Insight
5" Straight pipe
powerstroke_god is offline
post #4 of 13 Old 12-26-2012, 11:12 AM
taskforcefreddy's Avatar
No. You are fine. Two things. 1. Replace T-stat 2. Need to check deltas at a slower speed like 60-65. After 4 hours, my deltas @ 70-75mph are 11-12 degrees. While doing 60mph, my deltas are at 7 degrees so you can see how the higher speeds cheate the higher temps. I also have switched out my coolant to ELC so I'm quite certain my oil cooler is just fine.
taskforcefreddy is offline
post #5 of 13 Old 12-26-2012, 11:17 AM Thread Starter
Will look into that when I get to tx tomorrow morning. Is the tstat hard to replace?
Rob
SSgt, USMC
MBRP 4" Turbo Back
Kitty Delete
SCT X3 Looney Tuned
Edge Insight CTS
Home Brew ZooDad
post #6 of 13 Old 12-26-2012, 11:18 AM Thread Starter
And no filter. I love having this app on the road!
Rob
SSgt, USMC
MBRP 4" Turbo Back
Kitty Delete
SCT X3 Looney Tuned
Edge Insight CTS
Home Brew ZooDad
post #7 of 13 Old 12-26-2012, 11:21 AM
T-stat is easy... you just need to have some coolant with you to replace the stuff you'll lose when pulling the t-stat housing off. Next step is putting a coolant filter kit on. After that you'll want to change out your coolant and replace it with EC-1 rated ELC collant.
post #8 of 13 Old 12-26-2012, 11:22 AM Thread Starter
Been running 65 for about 15 minutes. Delta is 8 now. ECT still low 180's
Rob
SSgt, USMC
MBRP 4" Turbo Back
Kitty Delete
SCT X3 Looney Tuned
Edge Insight CTS
Home Brew ZooDad
post #9 of 13 Old 12-26-2012, 11:58 AM
id replace the t stat and compair the results...change it when the truck is cold to and not under pressure
2006
, Fuel Pressure)
Eric
post #10 of 13 Old 12-26-2012, 12:01 PM Thread Starter
Thanks bud! It's 32 in weatherford tx so cold won't be an issue! Well not for the truck but it might be for me!!
Rob
SSgt, USMC
MBRP 4" Turbo Back
Kitty Delete
SCT X3 Looney Tuned
Edge Insight CTS
Home Brew ZooDad
