Eot & ect GVW is 20000# is this to high? - Ford Powerstroke Diesel Forum
Old 12-13-2012, 12:39 PM
2004 6.0, 15k miles ago 4in Mbrp exhaust,no cat or muff, Egr delete, new oil cooler, flushed coolant and put coolant filter on.
I've recently bought a SCT tuner, I'm running the caned tunes, tow package + 65hp
Truck and trailer weighed 20000#
My ect was around 210 and eot was around 230! IS this to high?
Just seems to be a big gap between the two?
Old 12-13-2012, 12:48 PM
Send a message via AIM to Powerstrokinva
Everything I have read says no more then 15 degrees when running on a flat road at highway speeds for 10 minutes or so unloaded. Try that scenario and see what it reads.
Old 12-13-2012, 01:27 PM
Did you delete the egr cooler too?
Old 12-13-2012, 01:48 PM
Almostdunfukinwidit
The 15 degree delta does not apply with a trailer on
Old 12-13-2012, 01:56 PM
Those temps are fine, and expected towing that trailer. I wouldn't expect to see any higher temps or more spread though, that trailer is not super heavy. Real question is what's your delta unloaded?
Old 12-13-2012, 01:58 PM
Yeah it doesn't apply with a trailer on but yeah check out your deltas unloaded at 65.
Old 12-13-2012, 02:27 PM
What are you running for oil? You should be running a synthetic 5w40. It is much more capable of protecting your engine at high temps than dino oil. Overall your temps are not out of line for that weight.
Old 12-13-2012, 03:32 PM
Running rotel oil not synthetic though, egr cooler was deleted, empty my deltas are 5-8
What is hot for eot?
Old 12-13-2012, 04:21 PM
I ran up a long long grade today. From Las Vegas to Baker very long IMO and I ran up 50-60 MPH towing my 40' Montana 5th wheel. Loaded down and towing a dirt bike trailer behind. About 15k plus the truck and the highest I saw was 229. Rotella t6 oil and mbrp 4" no CAT no other mods. Stock tune
Just FYI to compare
Sent from my iPhone using AutoGuide.com App
Old 12-13-2012, 04:34 PM
With oil temps of 230* plus I would really want a synthetic oil in the truck, but with all the evidence concerning how much better synthetic oil is than standard dino oil for these trucks I don't understand why anyone would continue to run dino oil in them.
