Alternator - Ford Powerstroke Diesel Forum
post #1 of 26 Old 12-13-2012, 09:50 AM Thread Starter
ShadowKev's Avatar
Alternator
I need a new one, Tousley has 4 of them, what are the differences in them and which one do I order?
http://www.tousleyfordparts.com/part...ion=ALTERNATOR
Sent from my iPhone using AutoGuide.com Free App
2007 F250 King Ranch STUDDED TUNED LIFTED
2016 Mustang GT
ShadowKev is offline
post #2 of 26 Old 12-13-2012, 10:05 AM
Mod Newbie
dhanna6powerstroke's Avatar
Quoted: 20 Post(s)
Just give them a call with the last 8 numbers of your VIN# and they'll give you the right part #.
dhanna6powerstroke is offline
post #3 of 26 Old 12-13-2012, 10:08 AM
Mod Newbie
Quoted: 20 Post(s)
It'll either be the 3rd or 4th option unless you have dual alternators.
post #4 of 26 Old 12-13-2012, 10:21 AM
Chadly329's Avatar
What year is your truck? Pure Diesel Power | Diesel Performance Parts | Diesel Power Chips has 03-05 alternators for $185.00, I'd try that.
2005 Black F250 Lariat CC/SB FX4
EGR Delete
OEM Oil Cooler Upgrade
CAT EC-1 ELC Coolant
Garrett Powermax Stage 1 Turbo w/ Wicked Wheel 2
ARP Studs, Stock Head Gaskets
Sinister Diesel Oil and Coolant Bypass Filtration
ATD Rebuilt Transmission
Blue Spring Upgrade
Amsoil w/ Billet Fuel and Oil Filter Caps
River City Diesel 155cc Injectors and HPOP
SCT X4 Tuner
6.0 Powerstroke Diesel
Thank You!
Ryan and Chris at ROCK DIESEL OF MILTON
Chadly329 is offline
post #5 of 26 Old 12-13-2012, 10:23 AM
Powerstroke Techie
Lilpooh's Avatar
Feedback Score: 3 reviews
The top alternator on the dual alternator set ups will work on a single alternator truck. A original single alternator truck alternator is 110a, the top alternator on a dual alternator truck is 140a.
For $23 more, you get 30amps more.
Sent from my iPhone using AutoGuide.com App
2004 F350 CC DRW King Ranch
X-3 tunes by DJ'S,QT,GH,ID. Gryphon FICM tunes, ARP studs,Stage 1turbo,ATS coolant recirc lines,Swamp's 48v ficm,coolant filter,AD2,Snow Perf stage II,EGR delete,4" turbo back straight pipe,S&Bintake,Quad "A" pillar autometer gauges,Suncoast Tri Disk Conv.,Billet input shaft,Suncoast superduty rebuild kit,Trans-go shift kit,Mag-Hytec trans pan,CFM+ elbow,ccv mod,15K reese 5er,17" LCD TV/DVD,Cobra 29 Nitewatch CB
Lilpooh is offline
post #6 of 26 Old 12-13-2012, 10:34 AM
for $200 dollars you can get a 200 amp from mechman
2004.5 Mods: CTS, Lots Of Gauges, 7 inch Stack, ARP Studs, Tuned by Eric, SAP Diesel Full Fuel System, WEP Ported Intake Manifold, Mechman Alt, BPD 6 Phase Ficm, BPD Oil Cooler, BPD Oil Bypass, Warren 350cc conventionals, SAP Diesel/Warren Diesel Twin Pump Kit, SAP Diesel Triple Turbos and SAP Diesel Trans in Progress.
g2shuck is offline
post #7 of 26 Old 12-13-2012, 12:28 PM
Snake's Avatar
Quoted: 46 Post(s)
My factory alternator died after two years, and the "new" OEM alternator that replaced it lasted less than that. Bought a 200a unit from alternatorparts.com and that lasted just over 2 years. Figured I'd try DB Electric and that alternator was bad right out of the box. Sent it back and got my money refunded. So I pulled all the spare change out of the sofa and ordered a 300a alternator from DC Power, but I haven't had it long enough to comment on it's service life.
Truckless
Bulletproof Diesel
KC Turbos
1-A Auto Parts
Snake is offline
post #8 of 26 Old 12-13-2012, 06:05 PM
Quoted: 8 Post(s)
Love my DCPower Alternator (250A)!
You should NEVER go back in w/ a 110A unit. At LEAST upgrade to the Ford 140A unit as mentioned earlier!
Mark
06 F250CC SB FX4 Lariat;ARP studs;OEM gaskets; Banks exhaust;DynaTrac Ball joints;Coolant filter; High-Idle;RACCCV6000;JimmiJammers;Ravelco;SynchroMax trans case;Fumoto valves;Harpooned;CPOhighwayProducts toolbox;tracrac;Fox Weatherboots;Wet Okole Seat Covers;BriteBox;Re-flashed;Quadzilla Recon XZT Fuel Press;Blue FPR spring;DashDAQ;PHP FICM;RiffRaff boots;DCPower270AXP;PowerInverter;Rancho7000's; BPD EGR cooler;One-piece HPOP fitting;BilletWaterPump;SCT w/ Matts SRL;ELC Ultra
bismic is offline
post #9 of 26 Old 12-13-2012, 06:07 PM
Powerstroke Techie
Quoted: 15 Post(s)
Garage
Feedback Score: 4 reviews
I'm running an OEM 140. not a reman either, couldn't be better
-Matt
Ford Senior Master Tech
2015 F-250 XLT 6.7L
2006 F-250 6.0L SOLD
sinner6.0L is offline
post #10 of 26 Old 12-13-2012, 06:17 PM
Mod Newbie
Quoted: 20 Post(s)
Here's my question. If you aren't running anything extra on the electrical system like stereos, lights, etc., will it hurt to put a high output alt on the truck?
