Nasty oil cooler pics
Check these out...and I would like the experts to chime in. This cooler had about 125k miles on it. Does what you see look like typical ford gold "silicate goo"? Or is this more likely from coolant mixing? More details in another post...but new cooler is clogged again after about 1500 miles.
Will a really good chemical flush get rid of all this nastyness? http://s1239.beta.photobucket.com/us...29362749102426 |
that is pretty bad. the oil cooler looks almost orange though, was the veh run on dexcool?
If it wasn't dex then that is surely rust |
Ford gold best of our knowledge. Truck was bought used with right at 90k. Few minor things on Oasis, but nothing major at all. Waited too long to put monitor on it (Dad hard headed).
It feels like paste rubbing between your fingers. Gritty, but not that bad. Rust is a possibility. Will the rust/scale remover part of the flush routine clean one that is that bad? Would you recommend doing that part of the procedure twice possibly? |
bump to top
It is a combination of particulate from the old coolant, rust (block) and minerals (water). Old coolant gets very acidic. Eventually the coolant can not hold the ions in solution and they precipitate out. There is no way a chemical flush will fix any of that, except it might work in the block. There is probably so much goo in the whole system that you will need an EGR cooler and to look at potentially even a new rad! Unfortunately, you could probably expect more clogging of new components with out a lot of work!
Thanks for the response. A lot of work doesn't scare me, just want to get it right.
The new oil cooler plugged pretty fast, and the truck did not have a chemical flush to begin with. I will also install a new radiator after flushing to be sure. Just really trying to figure out what order I should proceed in. With changing the oil cooler again being last. The truck now has an EGR delete and a sinister coolant filter installed. |
Flush (chemicals), install coolant filter and drive, then change the oil cooler. Or even better, buy a Bulletproof Diesel oil cooler. It'd be damn near impossible to clog it, and you eliminate the risk of ever getting oil in your coolant.
Pretty much what I was thinking....but wanted to be sure.
Dad has been driving with the coolant filter installed for a few thousand miles now, changed the element 3 times, and honestly it didn't have what I expected in it. As bad as the original oil cooler looked....should I maybe "double up" on the flush procedure? Or is that a waste of time/money? I will be doing the labor myself this time, so money there isn't an issue. Just want it right. We will do the flush/OEM cooler one more time. If deltas are still an issue, then the BPD cooler will most likely be installed. Thanks for the help |
I suspect you will need to replace the heater core, radiator and another oil cooler, there is a used one in the for sale section that had an 8° delta, you could use that for your next "filter". Hate to see someone screwed that engine over like that.
Sent from my phone that somebody didn't help me get. |
How hard is the heater core to get too in an 05 F250? I had to change one in an 88 Mustang GT years ago and it was a PITA! But I was also 16 LOL.
So even with a good flush you think Im most likely going to clog the next cooler too? The one in the pics was the original one, and the new one clogged in 1500 or so miles. Deltas now 25* or so. |
