Research for Build (Head Studs)
I have done a lot or reading and I am saving up the funds to do a head stud job due to my oil cooler taking a dump. She has 180K miles and has the HPOP STC upgrade already. I plan on taking the front bumper, grill, etc. off.
Below is a list of the must do / must have parts. Please chime in if I am missing anything, especially any gaskets! Turbo Drain Tube Turbo Seal Kit Intake Gaskets EGR Delete Oil Cooler HPOP Extreme Duty Stainless Steel Screen ARP Head Studs ARP Ultra-Torque Assembly Lubricant OEM Head Gaskets Updated Stand Pipes and Dummy Plugs Machine Heads w/ Coolant Recirculation? 175/stock cc Injectors Injector O-Ring Kit Rocker Box Gaskets Exhaust Manifold Gaskets Coolant Thermastat Stant Cap Coolant Bottle Main Drive Belt Secondary Drive Belt IPR High Flow Coolant Filter w/Coolant Manifold Oil and Oil Filter CAT Rated EC-1 ELC Coolant VC9 (or Fleetgaurd Restore) I am concerned with balancing unnecessary spending with smart maintenance decisions. Below is a list of "while I am in there" parts I have thought about replacing and would like your thoughts on do it or wait and put the money in a MMW turbo, etc. I do not have the funds for my entire dream list. Who does, right? Automatic Belt Tensioner w/ Dual Alternator Glowplug Harness (x2) New Golwplugs Bulletproof Diesel Water Pump Fluidampr Harmonic Damper - Dual Alternator Mishimoto Radiator Turbonetics / Spearco Intercooler |
I would go with the all aluminum radiator that Bullet Proof Diesel sells It's $327. I just got one an it is half the cost of the Mishimoto Radiator!! If yours is not leaking I would probably hold off on replacing it if your trying to cut cost. I'd do the water pump with those kind of miles on it. I just changed mine because I was at it with the radiator out and the plastic impeller had slipped enough on the shaft it was rubbing the front cover the bearings were still good and tight at 117,000miles. Would have not known it was rubbing if I hadn't removed it.
Intake Gaskets Reusable
Rocker Box Gaskets Reusable Glowplug Harness (x2) Get for Sure New Golwplugs Not needed I would strongly suggest that you flush your coolant system with restore/restore+ a week or two before tearing into it. Then drive that week and all and any junk left over will find its way to the old oil cooler and clog it. THEN do the build and replace with a new oil cooler. If you do the flush and NEW oil cooler at the same time. As soon as you start driving after the build there is a good chance your NEW oil cooler will get clogged with the leftover junk in the coolant system, because the flush Never gets ALL of it out. Just My .02 |
Reusable gaskets is what I like to hear! Which gaskets do I need to replace for sure? Turbo and injectors only?
Turbo, injector, exh manifolds, and HG LOL
Yeah, head gaskets is on the list...carved in stone. Thanks.
Might be worth it to do push rods while you're in there, and they're cheap. Maybe the updated fuel pressure spring (blue spring) and possibly 6.4 banjo bolts.
The fuel pressure spring (blue spring) and 6.4 banjo bolts are on my master list. Thanks for the input! |
subscribed.
