EGR delete from Alligator Performance
So i believe my egr cooler is starting to go. So i recenetly got a good deal on an egr delete from alligator performance. Now Ive been doing a lot of research on this and notice a few people mention brass fittings. They mentioned brass fittings not being very good but not much more and i cant find anymore info on it. Now my concern is, the kit that i got, which is a DRP EGR delete kit, has brass fittings.
Is it really that bad if it has brass fittings or is it more of a preference? I plan on getting this done soon so im just worried and dont wanna have to change it again later on. Thanks in advance everyone. |
Brass fittings are fine. They are widely used in tractor trailers for air. They are currently being used as coolant fittings on egr coolers. I only see the hose clamps leaking nothing wrong with the fittings.
you also nee to put an oil cooler in while you have it apart.
Jake is 100% correct brass has no enemy with aluminum or steel it is fine!
Awesome, thanks for the help guys. And too be honest i wasnt planning on changing my oil cooler. My reasoning being that my deltas are usually no more than 7* apart, and since I am on a budget, i cant see myself spending more to fix something that isnt necessarily broken. Although i could be wrong lol.
brass and steel are NOT compatable... the two together create Galvanic Corrosion... but will you have an issue? i dont think so.
Well any good brass fitting should be coated to prevent this! And I say good fitting!
