Replace fan clutch? - Ford Powerstroke Diesel Forum
post #1 of 22 Old 12-11-2012, 02:15 AM Thread Starter
Replace fan clutch?
Ok so I as having tranny issues with my truck. I take it to dealership they say it's because the wiring harness from the fan clutch has been cut. I've heard of that issue but not when it comes to causing tranny issues. So I need to replace fan clutch? I haven't seen cut wires yet but I'm guessing splicing wouldn't be a good solution. Dealership wants over $700 to do it. Is that normal price? Also how much of a pain is it to do yourself? What do I need? What's the steps? Do I need anything besides the fan clutch parts wise? Wiring harness comes on clutch right? Any help would be greatly appreciated thank you!!!!!
"the C4 6.0" 2004 F350 srw lariat CC
ARP's, Liberator fire ringed heads, EGR delete, Brute Force CAI, 6.4 banjos, blue spring, cfm+, Livewire TS custom tune, 5"turbo back with 4" down pipe. Cowel Hood. Lifted on 35's. Suncoast tranny. Newly added 05 grill and harley headlights.
Amfw119 is offline
post #2 of 22 Old 12-11-2012, 03:57 AM
Quoted: 58 Post(s)
Change it yourself. Isn't that hard, though the stator and shroud are a pain in the a$$. Harness is connected to the clutch so you will get a new one. Only special tool needed is a large wrench for the nut on the fan clutch. Took me about 3 hours and it was my first time doing so.
Would not pay the dealer >$700 for the work, as the part can be had for ~$250 from Diesel Filters Online: [YB-632]Motorcraft cooling fan clutch(YB632/4C3Z-8A616-AA) - Diesel Filters,Additives,brake rotors, and brake pads for Chevy, Dodge and Ford Diesel Trucks
2016 F350 CCSB 4x4 6.7 FX4 Lariat Ultimate
Ruby Red with Black Leather
3.55s, OEM 20s, Locking Rear Diff
Icon 2.5 CDCV Shocks
TufTrucks 2.5" 7,500 lb coils
Carli Radius Arms
Carli Track Bar
Carli High Mount Stabilizer
Titan 50g Midship Tank
295/65/20 Nitto Ridge Grapplers
Previous:
2006 F250 CCSB 4x4 6.0 FX4 Lariat Ultimate
All the BPD goodies
skanj0 is offline
post #3 of 22 Old 12-11-2012, 04:34 AM Thread Starter
Ok good info thanks alot
Amfw119 is offline
post #4 of 22 Old 12-11-2012, 05:01 AM
kinnisoj's Avatar
Quoted: 2 Post(s)
I second the whole change it yourself. All you need is very basic tool set plus go down to your local Autozone and rent a wrench fan. Defently not worth paying someone $700.
,edge turbo timer
5" TB DIAMOND EYE EXH
ATLAS 40
TITLE IN HAND...
kinnisoj is offline
post #5 of 22 Old 12-11-2012, 05:30 AM
ZMANN's Avatar
Quoted: 1583 Post(s)
there is nothing magical /shielded/coax/ about those wires .. if the damage is accessible a good repair is fine
I am getting ready to swap mine out to the snowplow package clutch along with the bulletproof water pump /idler and t stat just for reliability
We Miss you Ronnie
ZMANN is offline
post #6 of 22 Old 12-11-2012, 05:43 AM
Quoted: 28 Post(s)
There is a replacement wiring harness for that and it is wrapped up by metal staples or something. It prevents it from getting cut and I think its around ten bucks
06 350 CCLB
Edge CTS
Up-Pipes by Cutting Edge
ARP's
Bulletproof EGR Cooler
Coolant filter
rentstdi is offline
post #7 of 22 Old 12-11-2012, 05:54 AM
ZMANN's Avatar
it can't be a replacement harness that is internal to the clutch
I think that part is just a shield
We Miss you Ronnie
ZMANN is offline
post #8 of 22 Old 12-11-2012, 05:58 AM
ZMANN's Avatar
here is the ford fix
We Miss you Ronnie
ZMANN is offline
post #9 of 22 Old 12-11-2012, 05:59 AM Thread Starter
Ok question because I ran into this question when ordering clutch. What's difference between the regular and snow plow package one? Are they simply interchangeable? An te shield is available from where? Send like a good insurance policy for ten bucks.
Amfw119 is offline
post #10 of 22 Old 12-11-2012, 06:00 AM Thread Starter
Oh I see now bullet proof diesel. Thanks!
Amfw119 is offline
Tags
6.0 , fan clutch , powerstroke
