Door Squeak driving me nuts - Ford Powerstroke Diesel Forum
Old 12-11-2012, 01:36 AM
So as the thread title states there is a squeaky noise coming from around ear level right at my door and it is driving me nuts. Has anyone had this problem or know how to fix it? I thought maybe it was the plastic at first so i held it really tight but there was still the annoying noise. I am thinking that it is the rubber weather stripping that runs around the door frame. Could this be the problem? Any help or leads on where to fix this greatly appreciated, and hopefully i posted in the right section.
Old 12-11-2012, 05:56 AM
Put some armor all on a rag and wipe the seals down.
Old 12-11-2012, 07:13 AM
Feedback Score: 5 reviews
3/8 OD surgical tubing stuffed in the weather seals on the door frames.
Popular mod
BTW, I still need to do it
Old 12-12-2012, 03:55 AM
I have all the stuff to do mine... but the ambition and now its cold outside...
Old 12-12-2012, 06:39 PM
I pulled the weather seal off my drivers door and pulled 3/8" clear vinyl tubing through it. its like 10 to 12 feet long. Had to use a electricians fishing ling to pull it through the hole. Door shuts tight and no squeaks, one day I'll do the other 3. Got vinyl tubing from home depot, they were out of the 3/8" surgical tubing which is a lot softer and probably would of went through the hole a lot easier.
Old 12-12-2012, 06:57 PM
Wow the people on this site rock thanks to all
Old 12-12-2012, 06:58 PM
good to know i will try this some day
Old 12-13-2012, 03:05 AM
Wanna see it done?
Old 12-13-2012, 04:08 AM
Good info
Sent from my iPhone using AutoGuide.com App
Old 12-13-2012, 05:21 AM
Yea the tubing is a good mod to do IF it needs it, it may not. And the weather strip might not even be the squeak on this truck. That's why I suggested the armor all, so he can find out if its even the weather strip cheap and easy.
