Keypad Help - Ford Powerstroke Diesel Forum
post #1 of 10 Old 12-10-2012, 03:15 PM Thread Starter
Keypad Help
I purchased an F350 Lariat last tuesday that has the keyless-entry pad on the drivers door. Problem is, the previous owner didn't know the code and the paperwork with the truck doesn't include this info. Does anyone know who to contact to figure this out?
Thanks, Mike
mikeg1652 is offline
post #2 of 10 Old 12-10-2012, 03:22 PM
ZMANN's Avatar
Quoted: 1478 Post(s)
should be a Google search away .. it's written on the GEM module or pay a dealer to get it
I Googled it and found mine on the GEM module
We Miss you Ronnie
ZMANN is online now
post #3 of 10 Old 12-10-2012, 07:55 PM
If the key pad is factory installed(hole in the door) the code is located under the dash on the module. The module is in the center behind the climate controls. You will need a small telescoping mirror. If you lay on your back in the floor on the drivers side and stick your head by the go pedal and look up toward the back of the radio you will see the module. There is a sticker on it that you need the mirror to read the code off of. If it is a dealer add on pad(stick on) it is different
2004 F350 6.0L King Ranch CC, LB, Dually, 4x4, EGR Delete, Dieselsite Coolant Filter, Edge Insite CTS Monitor, BPD Billet Water Pump and All Aluminum Radiator
ovrtrn is offline
post #4 of 10 Old 12-11-2012, 04:00 AM
ejg3855's Avatar
I found it was easiest to pull the panel there. Then have one person with a flash light look in and the other push wire harnesses out of the way.
Took about 10mins.
ejg3855 is offline
post #5 of 10 Old 12-11-2012, 05:21 AM
kendallcschm's Avatar
Send a message via Skype™ to kendallcschm
can we get a picture of someones GEM module so we know what we're looking for
2007 Ford F250 Lariat 6.0 Powerstroke
mods:
Banks Ram air
Sinister Coolant Filter
Swamps 48V FICM with PHP Atlas 40
B&W turnover ball hitch
EGR Delete
Diesel Site Intercooler Boots
SCT livewire TS 5015 w/IDP custom tunes
Agressive street, Tow W/jake brake, Economy
Other rides:
2010 Ford Explorer 4.6 24V V8
1999 Ford Mustang Cobra 4.6 32V V8
Mods:
JLT True CAI
Smoked Heads/tails
kendallcschm is offline
post #6 of 10 Old 12-11-2012, 06:28 AM
Aretoo's Avatar
Here you go. Look at post #9 and there are detailed instructions and some pics.
Keyless Keypad Code - Ford Truck Enthusiasts Forums
Hello, my name is Nathan...and I am addicted to my skinny pedal!
2006 F250 Crew Cab Short Bed
Harley Davidson Edition # 01592
MODS
ARP Studs
Edge Insight CTS with EGT
IPR Gen2 EGR Delete
MBRP 4" turbo back
PHP Atlas 40 FICM Tune
Gearhead tunes
Rotella Ultra ELC
Aretoo is offline
post #7 of 10 Old 12-11-2012, 07:49 AM
rvincent's Avatar
You could call the stealership and c if they will do it for free thats what i did they had there service mngr do it and i didnt even buy the truck from them, he even reprogramed it for me took him 5 min, never hurts to ask.
rvincent is offline
post #8 of 10 Old 12-11-2012, 07:51 AM
Quoted: 357 Post(s)
Feedback Score: 5 reviews
My dealer found the code and tought me how to reprogram it for my own code for free.
Edit:
Just looked on that website. Dang, it has a very good explanation
2005 F250 King Ranch Work Truck.
Studded and Deleted
175/30% Injectors from WARREN DIESEL!!
Barder Stage 2 Turbo
Warren Comp Tranny w/ PI TC
Six0~Stroker is offline
post #9 of 10 Old 12-11-2012, 08:16 AM
my stealership said they need to put a whole new module in and it would cost 900-1200 bucks and i said "i'm good" thanks for that thread with the info!
mods:
Banks Ram air
EGR Delete
Other rides:
Mods:
JLT True CAI
Smoked Heads/tails
post #10 of 10 Old 12-11-2012, 10:06 AM
thepowester's Avatar
I just did mine took a little longer cause I had to pull out the radio cause my XM box was in the way. But I got the code cleared the others and set a new one
Sent from my iPhone using AutoGuide.com Free App
2005 F250
AIRRAID CAI
MBRP 4" TURBO BACK
EDGE INSIGHT CTS W/ EGT
BLUE SPRING
6.4 BANJO'S
4" LIFT 35X12.5X17 FEDERAL M/T's ON XD REVOLVERS
thepowester is offline
