So toady i decide to change my coolant filter and cut it open to see what i have inside. I have the diesel site set up with baldwin filters and it has been on my truck for 500 miles.
![]() I drained my filter and got about cup and half of coolant. It came out real nice and gold, i drained it over a measuring cup with a coffee filter in between. No contaiminates were trapped. ![]() ![]() ![]() the housing looked clean with no contaminates around the walls |
i know when oil mixes with antifreeze it comes milky..what about when diesel gets inside coolant what does it look like?
Easiest way to check for diesel in your coolant is the tried and true sniff test.
It would still look like fuel as far as I can remember, ypu should easily smell it in the filter if you suspect it. Btw, 1k on my coolant filter, I had very little debris in the pleats, and caught very little in a coffee filter. Time for my oil cooler replacement.
Sent from my phone that somebody didn't help me get. |
it doesnt smell like diesel just like regular coolant
As far as OEM vs. BPD -- well, you can probably tell what my recommendation will be.
Cost is the number one reason I kept an OEM oil cooler. That I think there are enough components fighting for airflow behind the grille (rad/intercooler/AC) was why I don't like BPD's design. Finally, if I went 100k without a coolant filter, I should go mucho farthero with one on this new oil cooler.
23* degree split!?! Holy running on blind luck, Batman! I changed mine at 16~18. sent from a dumb guy with a smart phone |
