p0713 code ford - Ford Powerstroke Diesel Forum
Old 12-08-2012, 04:47 PM
p0713 code ford
Code just came on . Temp gauge is high and od light is flashing . My edge threw this code... Shifting was fine until I drove to the store and it was shifting firm or rough.... What's going on? Thought this is a sensor issue?
Thanks for the help
Old 12-08-2012, 05:05 PM
That's a code from the trans temp sensor. Check your trans fluid first off, then check the sensor and wiring.
Old 12-08-2012, 05:15 PM
Will the sensor being bad make it shirt hard or rough??
Old 12-08-2012, 05:44 PM
It could according to the symptoms I saw.
Old 12-08-2012, 05:46 PM
Ok so how hard is it to get to the sensor
Old 12-09-2012, 04:06 AM
Drain and drop the pan, the sensor is on the passenger side, you'll see the plug coming off of it. You turn it to the right I believe and pull down, when it comes out, about a quart of tranny fluid will come out as well. Would also be a good time to change the screen, filter, and fluid as well.
when you put the new one in, you will get a code for high voltage at the sensor for a few days, this goes away and doesn't harm anything. Also, check the wiring for nicks and scrapes, if you see any replace the harness.
Old 12-09-2012, 08:39 AM
Thanks.. How much is the sensor?
Old 12-09-2012, 06:39 PM
Bump bump bump
Old 12-10-2012, 07:19 AM
Also how much is the sensor?
