Cold weather question - Ford Powerstroke Diesel Forum
Old 12-08-2012, 08:50 AM
Here in a few days the temp will drop to around 31 degrees F, which isn't a very common thing in southeast Texas. I don't have to drive my truck, I can get around in my work car just fine, but would it be better for the engine if I started it and let the oil get up to temp, power up the block heater, or just let the truck sit and not start it until it warms up outside?
Old 12-08-2012, 08:54 AM
31 isn't cold. No need for the block heater at all. If you don't want to drive it it will do just fine sitting. I have started my truck at -7 without being plugged in.
Old 12-08-2012, 08:57 AM
Here in NC where it does go below freezing more often than Texas, I've (fortunately) never had to plug in the heater. She fires right up. HOWEVER, I always let the oil and coolant warm up to over 100* before driving and even at that, I don't get into it until she is at 150*+. Getting it to 100*+ at 32* may take some time so if you want to shorten the wait, then plug it in.
Old 12-08-2012, 09:08 AM
31 is nothing you will be fine!! Been up here in VT for a couple years havent plugged the truck in yet. It has started like a gem at -25 (did let you glow plug cycle a couple times first). Do let the truck warm up it will thank you for it
Old 12-08-2012, 09:11 AM
i plug my truck in just for a quicker warm up here in Kodiak, and personally i like to think its easier on the truck. but the truck has started right up in 10-20 degree weather with the coolant temp at 32 degrees. i defiantly let it warm up to at least 100 degrees before i start moving.
Old 12-08-2012, 10:09 AM
started her this morning @ 18* and she fired right up.......... drive it, she'll be fine.
Old 12-08-2012, 03:34 PM
Thanks guys, good to know the truck can tolerate the temps better than us southerners can!
