04 torque converter uncoupling with cruise on?
I noticed while running on the high way with cruise control on it seems the torque converter uncouples and rev's will run higher and don't seen to couple back up. Seems fine with cruise off, it will pull a good hill and not shift down or uncouple. Any thought's or idea's?
Uncommanded tc unlocks were the final throes of death for my 5R110. Is it slam shifting into 5th and hunting for 6th? Mine did that, too. It also had a pause when put in R or D.
sent from a dumb guy with a smart phone |
Every thing else seems normal and I never notice it unless cruise is on. Trans temp's generally run in 150's to low 160's at high way speed's.
the 5R110 (aka Torqshift) is a 5spd auto. the "6th" you mentioned is the RPM drop of the torque converter locking up (direct drive, 1:1). a constant lock/unlock of the torque converter is a sure sign of converter issues. you can try a flush and refill, but it will either prolong the inevitable or cause it to crap out completely.
1st 1stOD (2nd) 2nd(3rd) 2ndOD(4th) 3rd(5th) 3rdOD(6th) However, because 4th is 1.09 and 5th is 1:1, it shifts from 3rd to 5th. Thus making the shift pattern 1,2,3,5,6 TC lock. If you are basing your claim from an Edge monitor of gear indication, know this, Edge is counting the "shifting events" NOT the actual gear. The ONLY time a 5R110 uses 4th gear is when it is below 10*, even then it only shifts 4 times: 1,2,3,4,6. I know most websites show 4th as 1:1 and 5th as 0.71, but that isn't true. While I don't have the references, it's out there. I used to use Edge and thought that the 5R110 was strictly a 5 speed. The transmission settings on your SCT call for (among the other shifts) "3-5 shift pressure" and "4-6 shift pressure". Look up 3-5 Shift Flare in this forum or on Google, it is exactly what I am talking about. One last thought to throw out there, TCI is selling a 6-speed variant of GM's 4 speed 480LE. Do you know how they did it? It's an electronically shifted transmission and they reprogrammed it to shift like a TorqueShift. Simply, they use OD in ALL gears, not just HI gear. Click here, scroll down to the transmission part. http://www.intellidog.com/dieselmann/60psd.htm See page 38 on this PDF link also. http://www.fordtechservice.dealercon.../Dobdsm304.pdf Last edited by Karls03; 12-06-2012 at 11:25 AM. |
after reading this, 5R110 TorqShift Transmission Specs, i see what you're talking about. it is not a "true" 6 speed by definition, it technically has no 6th gear, just engaging 3rd and OD at the same time. its electronic witchcraft
i use SCT, not edge. Last edited by Int.Tech04; 12-06-2012 at 12:06 PM. |
That chart you referenced is not accurate. It is NOT showing you the true gear ratios that I referenced. Read over those links, the PDF says that if the OD clutch doesn't work you won't have 2nd, 4th, or 6th. Hmmm, sounds like OD is used more than just HI gear. These are 6 speeds, although 4th and 5th are so close it's pointless to use them in sequence. This is why these transmissions have been labeled as having "a hidden gear". 1st 3.11 2nd 2.20 (1st x OD) 3rd 1.54 4th 1.09 (3rd x OD) 5th 1.0 6th 0.71 (5th x OD) Engaging 3rd and OD at the same time is how the AOD, AODE, 700R4, 200R4 and every other automatic overdrive transmission out there does it. Gear Vendors's ad in the 90s was "Make your Power Glide into a 4 speed". |
Try running it stock and see what happens. When I had a superchip on my truck it would do that. It would be fine till you set cruise then the torque converter would unlock. It's never done it stock or with SCT.
