Can someone run OASIS Report for me?
I am buying my first powerstroke over the weekend, but want to make sure everything is ok on the OASIS Report. Can someone pull it for me?
Vin: 1FTNW21P84ED04696 Thank you! |
if u are buying from a dealer have them pull it
if not car fax isn't terrible but Oasis request are hit or miss on here just FYI |
Ok, I am buying from a dealer, but not a FORD dealer. I have the carfax vehicle history report, seems like it was maintained very well, just thought the OASIS would give me more information
it would
specially warranty items and dealer services but they aren't as available as they used to be ,, Only Ford folks can pull them and they monitor who pulls what anymore you might get lucky on here ,, ?? |
Here is the warranty history on your vin, Not much was done under warranty just some recalls, EGR valve, EBP sensor and the mainfold assemble on the fuel pump on the rail.
VEHICLE DESCRIPTION: 2004 F-SERIES BODY STYLE: F-250 CREW CAB 4X4 ENGINE: 6.0L OHV Diesel V8 TRANSMISSION: 5 Speed Auto 5R110W - HI/Torque AXLE CODE: C1 ENGINE CALIBRATION PAINT COLOR: Oxford White WB C/C PAINT CODE: Z1 RADIO: With AM/FM CD Player AXLE RATIO: 3.73 Ratio WHEEL SIZE: 8X18" Forged Polsh Alu Wheel Syt 2 FRONT TIRE: LT275/65R 18E A/T OWL GROSS VEHICLE WEIGHT: 8800 LB. GVW Production Date 02-APR-04 Warranty Start Date 06-AUG-04 Details 3592764 04C07 6 01-FEB-05 * * * 220987D Customer Comments RECALL 04C07 Details 7368999 59B01 15 .3 10-OCT-05 * * * 235425H Customer Comments PERFORM OPEN RECALL Tech Comments PERFORM RECALL 59B01 Details 7368997 05S34 15 1.3 10-OCT-05 * * * 235425E Customer Comments PERFORM OPEN RECALL Tech Comments PERFORM RECALL 05S34 Details 7368996 04B24 15 6.4 10-OCT-05 * * * 235425D Customer Comments PERFPRM OPEN RECALL Tech Comments PERFORM OPEN RECALL Details 7368998 05E15 15 1.3 10-OCT-05 * * * 235425G Customer Comments PERFORM OPEN RECALL Tech Comments PERFORM RECALL 05E15 Details 10028896 S07 25 2 B 07-AUG-06 4C3Z 9J460 A 251768A Customer Comments CUSTOMER STATES TRUCK HAS NO POWER Tech Comments CHECKED FOR NO POWER FOUND VERY SLUGGISH FOUND EGR TO BE STUCK OPEN FOUND EBP SENSOR TO BE STUCK REPLACED BOTH PARTS RECHECKED OK AT THIS TIME Details 11814610 E72 36 5.6 27-JUN-07 * 9D930 * 267263A Customer Comments VEHICLE LOSING POWER WHILE DRIVING, WATER IN FUEL LIGHT COMES ON FOR ABOUT 3 SECONDS AND GOES OUT, THEN IT HAS NO POWER Tech Comments PERFORMED ENG PERFORMANCE DIAG, CHECKED ALL VISUALS, ALL OK. RAN TESTS, RAN ICP TEST, FOUND OK. RANCRANKCASE TEST FOUND OK. CHECKED FOR EXHAUST RESTRICTION, NORMAL. CHECKED BOOST, OK. CHECKED FOR BAD FUEL, FUEL FINE. CHECKED INTAKE FOR RESTRICTION, FOUND CLEAR, CHECKED FUEL PRESSURE FOUND OK. FOUND RESTRICTION OK. CHECKED EGR FOR PROPER OPERATION, PERFORMEF FUEL OPERATION TEST, OK. FOUND SSM 17961 |
Thank you very much powerstroke4713! Since I am new this, is that a good sign that nothing major was wrong, or should I be looking for a vehicle where all the issues happened already and were fixed? I know the vehicle just had fluids changed ,new alternator, etc, in addition to the above mentioned items.
The 04's were a pretty solid year. The info I gave you only shows what was done under the factory warranty. The warranty has been expired for almost 4 years. The main concerns I would have are the maintance records. If oil, fuel filters and cooling system have been properly maintaned you should be ok. There is issues with the 6.0 but a well maintained engine has alot less issues. All the issues can be fixed and if you do some upgrades to it they are a really good engine.
Thanks again for the information....I have been reading for the past week or so about bulletproofing, but don't want to get the truck and then immediately do everything at once if I don't have to.....what would be the first few things to do (things that I could do myself) that would be helpful?
Coolant flush? Fuel Filter, etc?? Thank you for your help. |
How many miles are on the truck?
141,000 miles
