Stranded, truck will start then shuts down
I have a late model 04, I completed the egr delete and oilcooler replacement about 500 miles ago. I drove it on a 3 hr trip and noticed the cel came on with a ICP code about half way in to the trip, it still ran fine. I switched it off and would not start back up. Let it sit for 6 hrs and started it up ran fine for about 5 miles and quit again, let sit for 5 min and started up again, will stay running for 2 or 3 minutes and dies again. Not sure what is going on
Do you have a monitor, can you read icp, and ipr? Disconnect the icp and see if it runs.
Sent from my phone that somebody didn't help me get. |
I disconnected the ICP still want run
Do you have a monitor? It sounds like it may be combustion gases in the fuel rail. Pull the secondary fuel filler, hfcm fuse, and ficm relay. Crank the truck over and look for gas/bubbles coming up in the housing.
I notice when it dies and I try to crank it backup I don't here fuel pump running, but if I let it sit for about 5 min and switch on the fuel pump runs and it will start and run for a few minutes
you should here the fuel pump as well. Its underneath your butt! lol
