03 Motor Question. - Ford Powerstroke Diesel Forum
post #1 of 12 Old 12-05-2012, 02:40 AM Thread Starter
SySx's Avatar
03 Motor Question.
I have a 03 (02/03) F-350 and its about to go in for a lot of work ^_^. My question is I looked around and all of the dummy plug/stand pipe/turbo pipe and oil line are 04 and up. Am I mistaken or does these parts not work on my truck? Sorry I'm still learning.
Sent from my iPhone using AutoGuide.com App
93 Chevy Blazer R.I.P. Baby
03 Ford Lighting 500 hp SOLD
09 Dodge Challenger R/T SOLD
03 Ford F350 Crew Cab 4x4 SOLD
08 Ford F350 CCLB Dually Mini Maxx Race Tuner, Turbo Back Flo Pro 4" straight pipe dual exhaust
SySx is offline
post #2 of 12 Old 12-05-2012, 04:36 AM
dnf12908's Avatar
Quoted: 31 Post(s)
That's correct. the '03-early '04 have different oil rails and stand pipes, so you don't need the dummy plugs. The stand pipes should still be replaced if you are removing the old ones. The updated turbo feed line won't work on the '03 unless you've changed your oil cooler to the one with the updated cover.
Darrell
'03 F-350 6.0L C/C SB FX4 SRW
SCT X3 w/tunes by MKM
MBRP exhaust-turbo back
EGR delete
ARP studs
OEM gaskets
ELC coolant & filter
MTW Stage 1 turbo w/billet wheel
FPR (blue spring)
'04 upgraded front cover
BPD fan clutch adapter/w 7.3 fan
stator delete
All-aluminum intercooler(upgraded OEM unit)
Amsoil bypass oil filter
Insight CS monitor
Harley headlights
2008 rear diff. cover
EnviroSave powertrain treatment,
dnf12908 is offline
post #3 of 12 Old 12-05-2012, 05:07 AM Thread Starter
SySx's Avatar
Appreciated!
SySx is offline
post #4 of 12 Old 12-05-2012, 05:34 AM
southend's Avatar
Your 03, does not have standpipes our dummy plugs.
Sent from my phone that somebody didn't help me get.
Unfortunately had to Sell my ......2004 KR CC SWB FX4 - Edge insight cts, blue spring upgrade, updated HFCM drain plug, XDP coolant filter, CAT EC-1 rated coolant, Custom Diesel EGR delete, CAT delete, Rotella T6
SEE MY OIL COOLER REPLACEMENT AND EGR DELETE -
southend is offline
post #5 of 12 Old 12-05-2012, 05:47 AM Thread Starter
SySx's Avatar
I don't have standpipes or dummy plugs?
SySx is offline
post #6 of 12 Old 12-05-2012, 05:51 AM
southend's Avatar
No, go here and download the coffee table book.......http://www.forddoctorsdts.com/articl...icle-06-08.php
southend is offline
post #7 of 12 Old 12-05-2012, 05:56 AM
portcity_gt's Avatar
Quoted: 1267 Post(s)
I know it doesn't have dummy plugs because of the straight style oil rails......but it should have stand pipes shouldn't it. I know my 03 did, I replaced them.
03 cclb dually,6.0,arp studs,bpd oil cooler,bpd 6 phase ficm,bpd water pump,bpd all aluminum cac,all aluminum radiator,amsoil bypass oil filter,ipr high flow coolant filter,egr delete,livewire ts tuned by Vivian & tony,php ficm tuner,dc power 300-spx,Detroit trutrac,6" dual side pipes,07 front end,custom front bumper,shaved badges,led button roof lights,08+ mirrors,12 tailgate,13 rear bumper,13 tail lights,dropped I beams,custom rear 4 link w/bags,k5la train horn,24" alcoa's.
portcity_gt is offline
post #8 of 12 Old 12-05-2012, 06:30 AM
southend's Avatar
My early 04 didn't, the dummy plug is a cover for the extra hole on the oil rail, because the oil rail is interchangeable to each head. If you have a standpipe, you should have a dummy plug also. 03-early 04, have the old syle oil rail, that are connected with high pressure oil lines.
southend is offline
post #9 of 12 Old 12-05-2012, 07:03 AM
Yea, mine has the old style left and right specific rails, and the braided lines. But the braided lines snap to connect to a stand pipe that runs thru the head and screws into the high pressure "manifold" in the block.
One if my stand pipes came out fine when I did my head studs, the other one twisted befor it broke loose, so it prolly wouldn't be a bad idea to buy a set if taking the heads off.
I'll see if I have the part number for them at home.
post #10 of 12 Old 12-05-2012, 07:05 AM
southend's Avatar
I got you, i've only heard of those talked about once, forgot about that.
southend is offline
