Rev limiter? - Ford Powerstroke Diesel Forum
post #1 of 8 Old 12-01-2012, 12:54 PM Thread Starter
Rod Jr.'s Avatar
Quoted: 3 Post(s)
Rev limiter?
Coming down Cajon pass last weekend with trailer, tow haul engaged, when I tapped the brakes trans down shifted, rpm's went up to around 4,000 and heard a loud squealing sound, this is the second trip that this same noise was heard, any ideas ?
Rod Jr. is offline
post #2 of 8 Old 12-01-2012, 02:05 PM
Belt slipping
2004 F-350
Edge Insight CTS
4"MBRP Cat Delete
SCT tuned by Innovative
ARP Head Studs
03 Turbo
Leveled on 35's
Sinister EGR Delete
6.4 Banjo's Blue Fuel Spring
ELC Coolant/Sinister Filter
yarmish is offline
post #3 of 8 Old 12-01-2012, 02:26 PM Thread Starter
Rod Jr.'s Avatar
Quoted: 3 Post(s)
Is that normal ? Should it be replaced ?
Rod Jr. is offline
post #4 of 8 Old 12-01-2012, 03:11 PM
southend's Avatar
Exhaust flex joint cracked.
Sent from my phone that somebody didn't help me get.
Unfortunately had to Sell my ......2004 KR CC SWB FX4 - Edge insight cts, blue spring upgrade, updated HFCM drain plug, XDP coolant filter, CAT EC-1 rated coolant, Custom Diesel EGR delete, CAT delete, Rotella T6
SEE MY OIL COOLER REPLACEMENT AND EGR DELETE -
southend is offline
post #5 of 8 Old 12-01-2012, 04:45 PM
Check this as well
On the belt I would check it for any cracking and make sure it's good and tight
2004 F-350
Edge Insight CTS
4"MBRP Cat Delete
ARP Head Studs
03 Turbo
Leveled on 35's
Sinister EGR Delete
yarmish is offline
post #6 of 8 Old 12-02-2012, 01:01 PM
headviking's Avatar
How many miles on the belt? If you have over 60,000. I would change it and keep the ols one for a spare
If your commin, it's over. If your stroken, it's just started.
2007 F250 6.0L PSD Lariat - Dieselsite Coolant Filter - Bilstein Shocks - Blue fuel pressure upgrade spring - Country Duel Steering Stabilizer - Fumoto Oil Drain Valve - HFCM Water Separator Drain Plug Upgrade - ARP studded - Engine Oil (Rotella syth) - Rear Diff. & Front Axle (Royal Purple)
HeadViking
Helpful Links:
headviking is offline
post #7 of 8 Old 12-02-2012, 01:23 PM Thread Starter
Rod Jr.'s Avatar
Quoted: 3 Post(s)
Truck has only 33,000 miles
Rod Jr. is offline
post #8 of 8 Old 12-04-2012, 01:28 PM Thread Starter
Rod Jr.'s Avatar
Quoted: 3 Post(s)
Checked belt, tight and no cracks, do not see any cracks in pipe either. Any other ideas ?
Rod Jr. is offline
