Rev-x in the cold? - Ford Powerstroke Diesel Forum
Old 11-29-2012, 06:32 PM
Rev-x in the cold?
So I want to start running rev-x, but with winter in the sierras where temps regularly get down in the single digits and negative I'm not sure if its a good idea? What do ya think?
Old 11-29-2012, 08:04 PM
Rev X will make it run smoother when starting cold!
Old 11-29-2012, 08:07 PM
War is the answer!
Its a great idea. You actually might want to look into arcoil instead though. Cheaper and is the only one of the two to actually claim it fixes stiction.
Sent from my SPH-L710 using AutoGuide.Com Free App
Old 11-30-2012, 07:42 AM
I've run both. I currently have Archoil 9100 in the oil and 6300 in the fuel and cold starts (< 30 (f) ) are a non-event. Assuming that the rest of your engine is in good shape (FICM, high pressure oil, etc) running Archoil or Rev-X will certainly help in the colder months. After using Archoil, it is unlikely that I'll go back to Rev-X.
Old 11-30-2012, 09:04 AM
how much of the Archoil do ya run in the oil?
Old 11-30-2012, 09:23 AM
I just put some in on my on my last oil change, I believe the single bottle was 16oz
I also switched to Rotella T6, I'm a little warmer down here in Sparks but it's been starting up real nice in the colder weather.
Old 11-30-2012, 09:27 AM
16oz which is $35. I bought the EAC-1 kit which had the 9100 and 6300 for $80. It takes very little of the 6300 in the fuel. While many will claim that this stuff is snake oil, or that it is a bandaid to bigger problems, I just love the way my truck runs while using this.
I only treat the oil in the winter, the spring - fall is without oil additives. I am not sure that I even need any additives for stiction, but like I said, I love the way it runs.
Old 11-30-2012, 09:47 AM
I had wondered if you could actually see a difference with the 6300. How long did it take to have an effect?
Old 11-30-2012, 09:56 AM
Yes, you can. I had a typo, it's 6200, not 6300. In any event here's a post that I made with the 6200: Archoil 6200 and math
Old 11-30-2012, 10:42 AM
Interesting. At my next oil change I'm going to try the 9100 instead of Rex-X, maybe i'll get the kit with the 6200 and try it.
