Hot start, normal crank, low idle
Hey guys
So I just started noticing this recently, if I run in a store quick and shut the truck off and come right back out to start it. Itll start but ill be at about 500 RPM's, throttle is non responsive, and engine sounds normal just no exhaust sound. The first few times it only lasted a few seconds now close to a minute. I will hear the turbo spool up and exhaust will kick in then the truck run great. Truck has 88,xxx miles Deltas are normal FICM is at 47.5 key on engine off Recently changed fuel filters Oil changed about 2k miles ago Any ideas? Last edited by NJstrokin07; 11-29-2012 at 05:05 PM. |
So I am pretty sure this is coming from a HPO leak. Problem as been getting progressively worse to the point im afraid to shut the truck off if id be needing it again within an hour. Today i ordered updated stand pipes, d plugs, updated STC fitting, and turbo mounting kit from Tousley for $150. I really hope this solves my hot start problems. Anyone have any tips, tricks, or things to look for while doing this process.
Thanks |
Sound like your on the right track. You dont have a monitor? A 3/8 air rachet or a small cordless impact will be worth its weight in gold.
Sent from my phone that somebody didn't help me get. |
I hope so it has really become a PITA! Yes i do have a monitor ICP is usually at 500psi while cranking, anything else i should be monitoring? I don't think my edge CS can monitor IPR. I have the air ratchet just need to get a new fitting before i start
No, you can't monitor ipr, thats the only thing I dont like about my cts. I monitor, ficm, ect, eot, icp, batt, boost, vgt, and trans temp, or trans gear.
I do monitor all of the above they all seem to be in order (for the time being) with the exception of trans i have a manual so no worries there.
inb4 Global Warming......
^ this kid must drive a prius
Thats looks rough, keep us updated.
