Coolant filter sight glass - Ford Powerstroke Diesel Forum
post #1 of 10 Old 11-28-2012, 08:21 AM Thread Starter
Chatham036's Avatar
Quoted: 136 Post(s)
what i am looking for can be found in the pictures at this link
Ford Truck Enthusiasts Forums - MoyockPowerstroke's Album: Coolant Bypass Filter
Can anyone tell me where i can buy this part? I have looked around online and have not found anything.
Comments or opinions expressed by me do not necessarily represent the views of PHP, its management, nor its employees. PHP is not responsible for, and disclaims any and all liability for the content of comments written by me.
Chatham036 is offline
post #2 of 10 Old 11-28-2012, 08:32 AM
twoicebergs's Avatar
Quoted: 47 Post(s)
Since you can look in the degas bottle, it is more for the looks?
This is similar: grainger.com/Grainger/LUBE-Flow-Sight-1U892?Pid=search
Frank
2007 F-250 Lariat Crew. MBM 190/50s,
KC-68 Stage 3 Turbo,
DashBoss/F/P, and a few other goodies
Stiction Problems - Fix it yourself! -
Want to modify your injectors DIY -
Working for Toys
twoicebergs is offline
post #3 of 10 Old 11-28-2012, 08:48 AM Thread Starter
Chatham036's Avatar
Quoted: 136 Post(s)
I would like to have the certainty that the flow if from my coolant filter which is why I would want the sight on one of the lines connecting to the filer housing itself. The flow into the degaussing bottle could be coming from other locations if I am not mistaken
post #4 of 10 Old 11-28-2012, 08:57 AM
Quoted: 47 Post(s)
If you are doing it for flow, you need to use a paddle wheel style or some other device that will show the movement. These just show clarity. If the flow stopped with just a sight gauge, you may not know.
Frank
Working for Toys
post #5 of 10 Old 11-28-2012, 09:26 AM
Powerstroke Techie
Lilpooh's Avatar
Feedback Score: 3 reviews
Just feel the lines going to/from the filter base. When filter gets clogged, the out going line will be cooler then in going line.
Sent from my iPhone using AutoGuide.com App
2004 F350 CC DRW King Ranch
X-3 tunes by DJ'S,QT,GH,ID. Gryphon FICM tunes, ARP studs,Stage 1turbo,ATS coolant recirc lines,Swamp's 48v ficm,coolant filter,AD2,Snow Perf stage II,EGR delete,4" turbo back straight pipe,S&Bintake,Quad "A" pillar autometer gauges,Suncoast Tri Disk Conv.,Billet input shaft,Suncoast superduty rebuild kit,Trans-go shift kit,Mag-Hytec trans pan,CFM+ elbow,ccv mod,15K reese 5er,17" LCD TV/DVD,Cobra 29 Nitewatch CB
Lilpooh is offline
post #6 of 10 Old 11-28-2012, 09:31 AM
mazsecond's Avatar
Feedback Score: 4 reviews
Seems like this would be more for looks, but it does look pretty cool!
mazsecond is offline
post #7 of 10 Old 12-24-2012, 03:08 PM
Paintingman's Avatar
I seen that sight glass here 6.0 oil bypass filtration system and parts 6.0 billet aluminum filter cap airdog II - Diesel Oil bypass filtration & Coolant kits Ford Powerstroke 6.0 Chevy 6.6 Dodge 5.9 & 6.7 Parts Filters Aluminum oil filter caps Powerstroke Crankcase vent
04 F250 PSD Every day work truck
3000 Watt inverter/Jotto desk laptop and printer
180cc injectors 70hp+/powermax turbo
Stage 1 fuel lines/58 volt FICM from swamps diesel
ARP studs/black onix head gaskets
ATS intercooler/CFM+/Airaid intake
Fluidamper/200 Amp alternator
SCT X3 innovative diesel
4" turbo back MRPB duals
Mag-Hytec diff./trans covers
Paintingman is offline
post #8 of 10 Old 12-24-2012, 03:40 PM
Quoted: 47 Post(s)
Just to be clear, the one you are referring to is only rated to 225*F. That would work for most driving, but doesn't leave much margin for hot engines.
Frank
Working for Toys
post #9 of 10 Old 12-24-2012, 04:30 PM
Look for flow in the degas bottle while shutting the output valve on the filter. This has always worked for me once the bottle got clear enough to see thru.
2004 F-250 CCSB, BPD oil cooler, edge insight CTS,
MBRP, blue spring, SCT(hoping to get custom tunes from Santa)
virginiagent is offline
post #10 of 10 Old 12-26-2012, 12:09 PM
The sight glass can handle up to 225* I'm sure it wont fail till 240* or more and if your running hotter than 225* the last thing to worry about sight glass failing .
I think the idea of the sight glass is not to watch the coolant flow into the degas bottle but by watching the coolant flowing through the sight glass you can tell if your coolant filter is flowing or clogging theirs no other way to see that unless you take the hose off.
