Overkill or not??? - Ford Powerstroke Diesel Forum
Old 11-26-2012, 03:07 PM
Overkill or not???
So im gana change my oil and flush my radiator theres a guy from powerstrokehelp.com and he says to only use a motorcraft filter, i have a wix and a motorcraft filter,the wix looks alot better.... flushing my radiator he makes it out to be an all day event with flushing it running it flushing it with distilled water then mixing my motorcraft gold with it i have no problem if i really need to do it this way but if i dont then why bother so what do you guys think?
Old 11-26-2012, 03:14 PM
MAD - Modification Addict
Feedback Score: 7 reviews
Don't listen to Bill Huit he is a complete moron but in this case he is 100% right only use motorcraft or Racor filters for you 6.0l Powerstroke.
Old 11-26-2012, 03:19 PM
Feedback Score: 3 reviews
This is why it's recommended to run Motorcraft filters.
http://youtu.be/ewhO1RtIP-Q
To flush your system correctly, it is an all day event.
Sent from my iPhone using AutoGuide.com App
Old 11-26-2012, 03:49 PM
That vid was alot of help with my filter
Old 11-26-2012, 05:22 PM
http://www.dieselfiltersonline.com/f...k-filters.aspx
Sent from my phone that somebody didn't help me get.
Old 12-03-2012, 06:24 AM
Originally Posted by Tuscany View Post
Don't listen to Bill Huit he is a complete moron but in this case he is 100% right. . . .
Bryan, I'm just curious as to your reasons for having a negative opinion about Bill Huit. I've been on this forum for several months and have read many of your posts. Obviously, you have an extensive knowledge base and your contribution to this forum is invaluable. However, I've also reviewed Bill Huit's videos, and for the most part he seems knowledgeable and his recommendations are consistent with the info I read on this forum (with the exception of his recommendation to use Ford Gold--that seems like a red flag to me).
Although you make not care for his personality, is there a problem with the info he provides? My knowledge base is pretty limited--I know just enough to be really dangerous under the hood of my truck. So, I need to be able to gauge when I'm getting good info and when I'm not.
Old 12-03-2012, 06:35 AM
ive watched almost all of his Videos, even his comparison between the 7.3, 6.0 and 6.4. everything i learned from him, i also read on this forum. i like his tear down videos of catastrophic failures of 6.0's. it really gave me alot of info of what not to do, and what to look for. his video on "buying a used 6.0" was great.
i would suggest Ford filters or equivalent, only problem is, i dont, i use our Fleetguard filters from work. i figure if International uses them on a Semi, they are good, plus the fuel filters look just like the ford fuel filters i removed. im also using a Fleetguard Stratapore spin on instead of the drop in ford oil filter. almost 3k on this oil change, and the oil looks like i just changed it in yesterday.
