P0148 Code - Ford Powerstroke Diesel Forum
Old 11-26-2012, 10:33 AM
P0148 Code
Hi all. I'm getting a P0148 (Fuel Delivery Error) on my 2004 6.0. The fuel filters were changed probably 3k miles ago and the truck appears to be running fine. Went about 300 miles this weekend with her and she ran like a top thru the mountains of NC. I've cleared the code several, several times but it keeps returning.
Thoughts?
Old 01-05-2013, 08:01 AM
Im having the same problem with my truck. fuel filters havent been changed in awhile. Runs good but keep having this stupid code. Just dont want to drive it and it dying on me.
Old 01-05-2013, 08:05 AM
War is the answer!
" There are several things that can cause that code, including interference or "noise" on the crankshaft position sensor and the camshaft position sensor circuits. It could be a faulty PCM (not likely), it could be that your PCM needs to be "reflashed", or it could be as simple as getting a bad tank of fuel.
The service manual basically says to check safety recalls, check for Technical Service Bulletins (and repair accordingly), and if none are found, clear the code and drive the vehicle to see if the code re-sets. If it does, then there is a big L-O-O-ONG list of things that need to be checked to verify the actual cause of the code.
There is however, a safety recall for the wiring harnesses in your vehicle that could potentially cause this code to set. If the recall has not been performed on your truck, you should be able to get this done for free at any authorized Ford dealer. This is Safety Recall Number 05S34."
Sent from my SPH-L710 using AutoGuide.Com Free App
Old 01-05-2013, 08:13 AM
Ok i will drive this tank out and change all filters. Im hoping its not the pcm those things are pricey arent they?
