Fuel pressure gauge install on an 04f350 - Ford Powerstroke Diesel Forum
Old 11-24-2012, 07:03 AM
Here is my fuel pressure gauge install. Fittings needed are 1.5metric to 1/8" npt, 1/8" 90 degree street, and teflon tape. Its is a tight fit and takes patience as you cannot put a socket of fittings due to pressure regulator in the way and limited space. Wired gauge with add-a-fuse links to 2 10 amp fuse terminals/ and 5 amp fuses for the gauge(2 fuses will be intalled in the add-a-fuse). wire to horn fuse#37 i believe for your 12v ignition, and wire to body security/4x4 module #19, and ground it to a 5/16" bolt that holds the fuse panel on the metal frame.
Old 11-24-2012, 07:34 AM
Looks great!
Old 11-24-2012, 09:23 AM
Nice, but for the love of god, get a socket to fit that fuel filter cap!!! Lol
Old 11-24-2012, 10:24 AM
Sears sells 24mm sockets for like 8 bucks
Old 11-24-2012, 10:33 AM
Lol, you guys cracked me up nothing slips by you.
Op good job, nice write up.
Old 11-24-2012, 10:51 AM
lol harbor freight is less
the only issue u may have is the sender being subjected to heat and vibration
some use a short braided line to isolate the sender
Old 11-24-2012, 11:05 AM
hahahaha!! ive had a socket for it for 5 years! lol that was done by previous owner lol
Old 11-24-2012, 11:06 AM
i want to replace all caps with billet caps... but no sense in wasting the money if all the factory caps dont leak etc etc.
Old 11-24-2012, 11:14 AM
The sender usually isn't the problem with vibration, depending on type, usually it is the gauge. Think of all the other senders on the engine.
Old 11-24-2012, 11:18 AM
^ yes sir this is why i mounted it like this and wasnt concerned. I guess time will tell but im not worried about it...
