Tight budget
I am on a fairly tight budget and am wondering what I can do to my stock 06 6.0 to beef it up without bulletproofing it. I have a k&n in it any idea on tuners and exhaust. I don't want to bullet proof it even though it is getting hard to start in the winter. Thanks for the help
What kinda budget are you working with? Fairly tight to Donald Trump and fairly tight to me probably wont be in the same ball park.....
If your on a tight budget, then skip the exhaust and tuner. Start with a monitor solution to check the health of the motor, you may end up on a tighter budget if you don't see what's going on with your motor. Catch any issues before they become BIG expensive issues.
Things to consider about owning a 6.0L Write Up: Monitoring the 6.0L PSD. Sent from my iPhone using AutoGuide.com App |
I have about 2500 give or take and I also pull about 15,000 horse trailer a couple times a month
Ya I gotta second lilpooh. If you got 2500 go with a EDGE monitor and that will steer you in the right direction....
I see you have a thread posted about cold start issues, this is where you need to have a monitor to see what's going on. You may have FICM issues and a weak FICM can cause injector damage.
You can also check FICMv with a multimeter, but still no excuse not to get a monitor solution FIRST before buying a exhaust or tuner. How to check FICMv with multimeter. Write Up: Monitoring the 6.0L PSD. Sent from my iPhone using AutoGuide.com App |
I also have money for repairs this is just looking for extras. One of my buddies has a monitor that I use when things seem off
Oops wrong link for FICMv, try this one.
http://www.swampsdiesel.com/site/how...oltageTest.pdf Sent from my iPhone using AutoGuide.com App |
IMO a monitor is probably the most used add on to the truck that I use. Its not something that you would put on and say "yup all is good" and then take it off. Its vital...imo.
