need help egr delete and oil cooler - Ford Powerstroke Diesel Forum
post #1 of 7 Old 11-23-2012, 08:38 AM Thread Starter
turbotibbo's Avatar
ok guys i really need some help here . i am forced to do my own egr delete and oil cooler rebuild . does any one have good links or wright up on this and part numbers of things i will need . will the turbo have to come off ? i have tried to research it my self with poor results . does any one no the screen part number and do you all think i will have troubl;e doing this on my own ......thanks
2006 ford f350 xlt cclb
blue spring mod
6.4 banjo bolts
gogo direct cluth solenoid
Insight cts with pyro
str8 pipe , fuel pressure gauge
air raid cold air
zoodad mod
high idle mod
sinister coolant filter kit ec-1 rated
58 volt ficm
powermax turbo , sinister y pipe
egr delete
sct x3 with running looney wild , spd early lock up
arp studs , updated stc fitting ,stand pipes,
dummy plugs , new oem injectors
turbotibbo is offline
post #2 of 7 Old 11-23-2012, 08:48 AM
Mod Newbie
dhanna6powerstroke's Avatar
Quoted: 19 Post(s)
Turbo has to come off and intake manifold has to at least be taken loose to do the delete.
dhanna6powerstroke is offline
post #3 of 7 Old 11-23-2012, 08:50 AM
Mod Newbie
Quoted: 19 Post(s)
You can definitely do the job. It looks worse than it is.
post #4 of 7 Old 11-23-2012, 09:03 AM
sealeveloc's Avatar
Quoted: 19 Post(s)
Its not to hard at all, but there are some frustrating times, when doing it for the first time. Such as the bolts on the up pipe(y-pipe) The Heat bakes them together. pb blaster is your friend on them, start soaking them days before. oil cooler rebuild kit comes with the screen your talking about. feel free to contact me with questions, Im no expert, but I did just swap my oil cooler so its somewhat fresh on my mind.
You may want to look into switch to ELC coolant. coolant flush required before oil cooler swap.
Byron
O6 350 XL
The usual I wanna go fast mods,
maybe a lil more,
maybe a lil less
sealeveloc is offline
post #5 of 7 Old 11-23-2012, 09:08 AM
Mod Newbie
Quoted: 19 Post(s)
Pull the inner fender well on passenger side. Will make it easier to get to up pipe bolts. I just break the bolts and get replacement grade 8 bolts to put back in.
post #6 of 7 Old 11-23-2012, 10:31 AM
Powerstroke Techie
Lilpooh's Avatar
Feedback Score: 3 reviews
Lots of tips/tricks, part numbers, and PDF's.
Oil cooler and EGR cooler service PDF files and notes
Sent from my iPhone using AutoGuide.com App
2004 F350 CC DRW King Ranch
X-3 tunes by DJ'S,QT,GH,ID. Gryphon FICM tunes, ARP studs,Stage 1turbo,ATS coolant recirc lines,Swamp's 48v ficm,coolant filter,AD2,Snow Perf stage II,EGR delete,4" turbo back straight pipe,S&Bintake,Quad "A" pillar autometer gauges,Suncoast Tri Disk Conv.,Billet input shaft,Suncoast superduty rebuild kit,Trans-go shift kit,Mag-Hytec trans pan,CFM+ elbow,ccv mod,15K reese 5er,17" LCD TV/DVD,Cobra 29 Nitewatch CB
Lilpooh is offline
post #7 of 7 Old 11-23-2012, 10:54 AM Thread Starter
turbotibbo's Avatar
sweet thanks a lot guys
blue spring mod
6.4 banjo bolts
air raid cold air
zoodad mod
high idle mod
58 volt ficm
egr delete
