Unit Bearing - Ford Powerstroke Diesel Forum
Old 11-22-2012, 02:51 PM
Unit Bearing
Is there a lot to it or special tools? Or just disassemble and reassemble? I looked but didn't find a lot if information on it. Thanks a lot!
Sent from my iPhone using AutoGuide.com App
Old 11-22-2012, 03:01 PM
It's not bad, pull brakes, Locking hub, and 4 studs hold it on. There are several videos on youtube that show how its done.
Old 11-22-2012, 03:09 PM
Illiana Chapter Director
Gotta have a pair of snap ring pliers and a stud remover comes in handy if the new bearing doesn't come with new studs.
Old 11-22-2012, 04:12 PM
Appreciated guys!
Old 11-22-2012, 10:03 PM
You can use 2 nuts to pull the studs if needed
Old 11-23-2012, 10:07 AM
the new unit bearing should come with new studs to install for the mounting, at least both of mine did anyways! Maybe a big hammer to knock the unit bearing loose to remove.
Old 11-23-2012, 10:16 AM
Thank you!
