2006 f250 slow cranking
I just replaced my EGR cooler and Oil cooler on a 2006 6.ol
it went bad while i was driving. when i took apart, i had coolant in the turbo , now that it is back together, it cranks really slow, I just replaced the batteries and still does the same thing. any ideas?? |
Sent from my phone that somebody didn't help me get. |
still the same thing, could there be left over coolant in the cylinders , making it crank slow??
I guess the big question is how slow is slow? If it is barely turning over the previous suggestions may find the problem. If it is not the power to the starter, then this is what you should do next.
It is possible to have fluid in the cylinder and a blown head-gasket causing the slow crank, but hydro-lock would be more probable. Damage would certainly be catastrophic if the engine were to fire up in this condition. Check your oil! Take a quick sample and re-plug. If you have coolant in there, it is possible you may have done more damage than you thought; head-gasket, rings and piston damage. The easiest way check for fluid in the cylinders is to remove glow plugs and try to crank. You would want to disconnect the FICM or just by-pass to the starter so it wouldn't start. I hope it is the power/connections to the starter or even just the solenoid or starter. |
I loosened the fan belt and cranked... still slowly, I then replaced the starter and still no chamge...... what next???
