EOT high.. ?
Hi guys, so I was heading hunting on Friday morning and I had a trailer and quad on the back, maybe 1500lbs, not heavy at all, and was on tow tune on scts canned tune, and eot's were hitting 220 easily. And at one point peaked at 225.. The ect's were about 200-215 while eot's were that high.. Also I was going up a long pretty steep grade while this was happening.
Is this normal? I couldn't imagine what temps I would see towing a 10,000 lb trailer.. And advice would help.. Thanks Sent from my iPhone using AutoGuide.com App |
If the temperature difference exceeded 15 degrees (EOT - ECT), then time for a new oil cooler.
Sent from my phone that somebody didn't help me get. |
thats what they usually say..but it also throws it off if u did a chemical flush..any crap floating inside ur degas ?
I tow 10k+ in the summer. I have never had my temps that high. And ya, the 15* delta thing doesnt really hold true if you are towing heavy. (though even towing 10K I havent ever had a 15* spread for more than a few seconds) Um 1500lbs, that shouldnt effect any temps and you should have minimal deltas.
If it was my truck I would do a flush but thats just me. Im sure someone will say dont do it. |
I won't say don't, but I will say a chemical flush will more than likely help clog an oil cooler. Make sure the ect and eot read the same after a cold soak. If you don't have a coolant filter, get one asap.
I would say a filter is a good idea as well. Maybe a flush and a filter then chemicals later. But ya, I love chemical flushes! yum!
yea i bet they clean out alot of $h!t..what about just a regular water flush then distilled? less of a chance of it clogging up
mhh maybe thats what ill do..i dont wanna clog it...probably use Rotella ELC
