Still have low boost
Past weekend I installed IPR Gen II EGR delete, Upgraded STC fitting, & oil cooler. Cleaned turbo for 2nd time(it has a lot of rust pitting on exhaust side) and I still have 19-20 PSI at WOT. Cant find any leaks in exhaust or CAC BUT I have been noticing that WOT VGT % is around 30-35 until i let off throttle then it goes down to 15%. Could it be a faulty VGT solenoid? Truck used to get 27-28 at WOT that is why I cleaned it the first time and never changed. This time I decided to do all three of the above upgrades. Any suggestions woul be appriciated.
Thanks BB Wolf |
yup sounds like the vgt solenoid is going up. As soon as you let off the throttle you should see immediately it go up to 55-70%
Would switching vgt solenoid with a friends solenoid tell me if mine was bad?
i dont c why it would hurt. Never switched them up before though
Be very careful doing a switch. KEEP THEM VERY CLEAN. Meaning, keep area free of dirt. And don't just drop the one you pull on the engine compartment or some where it can get contaminated. Have a baggie to drop them into. Better safe than sorry.
Immediately upon removal from turbocharger, place the suspect control valve in plastic tube container provided with service kit base #6F089. Handle the valve by it's solenoid body only. Do not attempt to clean or wipe oil off of valve. Do not let the valve come in contact with anything prior to placing it in the container. This includes rags or fabric gloves that could contaminate the valve mechanism with lint. From this file: (has torque values also, and a good read) http://www.fordtechservice.dealercon...6lvgtguide.pdf |
very good info man
