How long is a water separator good for you ask? - Ford Powerstroke Diesel Forum
post #1 of 16 Old 11-19-2012, 01:28 PM Thread Starter
10secondC's Avatar
At least 2 years if you go by my truck......Oh wait...what am I talking about!? We found a Napa filter in there....not a water separator. And they replaced the oil filter with a NAPA set up. Just the start of the good news. Got a nice leak on the harmonic balancer and the exhaust manifolds are both needing gaskets. The fan shroud is broken on the bottom and rubbing the balancer as well This is all ontop of replacing the FICM,Battery and alternator. Good thing the dealer I purchased it from went through the truck and made sure it was good to go. I have a list of what needs to be done,it's a long list. People are not going to be happy when I walk into that dealership Monday. The sh*t is going to hit the fan.
On a positive note I am shocked that I can actually feel and hear a difference in how the truck runs with the correct fresh filters and fresh Rotella.
2007 XL CC,DRW,4x4.
When I die I wanna go peacefully in my sleep like my Grandpa, not screaming in terror like the passengers in his car.
10secondC is offline
post #2 of 16 Old 11-19-2012, 01:31 PM Thread Starter
10secondC's Avatar
P.S.....If you are new to diesels as I am don't rely on the dealer to go through the truck, even if the owner is(now was) a friend. Nothing like being lied to to make your day.
2007 XL CC,DRW,4x4.
post #3 of 16 Old 11-19-2012, 01:33 PM
ZMANN's Avatar
Quoted: 1338 Post(s)
make sure you have an OEM oil filter cap
We Miss you Ronnie
ZMANN is offline
post #4 of 16 Old 11-19-2012, 01:40 PM Thread Starter
10secondC's Avatar
It does ....NOW.
2007 XL CC,DRW,4x4.
post #5 of 16 Old 11-19-2012, 01:47 PM
I cant even believe the difference in T6 and Archoil vs. Dino oil. I mean I knew it would like it, I didn't know it would like it this much.
Of course then after doing my axle seals 2 mos ago, my hub seals went out after that. So looks like another 200-250 for those to be replaced tomorrow. Cleaned out the vent tub, and broke a 15mm open end trying to remove the nipple into the axle tube, sprayed with some PB blaster and let soak, trying an impact socket on it tonight, or just running something through it to make sure its not jsut clogged..... Would love to save 250 right before the holidays.
Glad to hear you went over the truck yourself, and yes, I never take mine to a dealer anymore, do it myself, or get a shady tree mech.
madcat6183 is offline
post #6 of 16 Old 11-19-2012, 06:15 PM Thread Starter
10secondC's Avatar
After what it took to get the fuel filter housing off on the frame I will be doing exact maintenance schedules.We pulled the filter out and it was black...can't imagine that was good for fuel pressure.
2007 XL CC,DRW,4x4.
post #7 of 16 Old 11-20-2012, 05:58 AM
Slacker
Evil Eye's Avatar
Quoted: 190 Post(s)
Feedback Score: 4 reviews
Sorry to hear that, bro. As you know, these trucks need their maintenance and it's a noticeable improvement when they are well cared for. Best of luck and let us know what they say at the dealership.
Shawn Carlson
Proud Navy Vet
2005 F250, CCSB, 6.0 PSD, FX4 (The Sweet Unit is white)
2008 F350, CCLB, 6.4 PSD (Brad-the wife's truck is black)
Engine Mods:
Fluidampr
CCV Reroute (Reinstated)
4" MBRP Exhaust
MTW Stage 1 Turbo
Bulletproof 53V FICM
BulletProof EGR Cooler
BulletProof Water Pump
Riff Raff Intercooler Boots
Gogo Diesel Direct Drive Solenoid
BulletProof All-Aluminum Radiator
BulletProof All-Aluminum Intercooler
BulletProof Oil Cooler System w/ Bypass Filter
SCT w/ Custom Tunes (TSD, DJ's, Innovative, Gearhead, QuickTricks)
Exterior Mods:
Bilstein 5100 Shocks
Icon Adjustable Trac Bar
Firestone RideRite Air Bags
BDS Dual Steering Stabilizer
Aluminum Finned Differential Cover
Reese 16k Manual Slider 5th Wheel Hitch
Icon 2.5" Leveling Kit w/ F-350 rear blocks
20" BMF Novakanes wrapped in 33" Nitto Terra Grapplers
Evil Eye is offline
post #8 of 16 Old 11-20-2012, 06:12 AM Thread Starter
10secondC's Avatar
I actually went in this morning. I was going to wait but I need to drive to Ohio for Thanksgiving and right now I honestly don't trust the truck. Felt an injector miss this morning and that was the last straw. I know deep down all the issues with the Injector/s ,alternator,FICM are related to the battery with 2 dead cells that I found when I picked it up. Something that should have been dealt with before the truck was delivered, just like everything else should have been dealt with before the truck was delivered. I don't mind maintenance, just give me a truck I can maintain. I paid top dollar for an extremely clean and rust free truck(rarity here).....I expect it to run properly.
Anyway...I am dropping it off at noon. I told them I don't want it back till it's right. I am taking a rental to Ohio and enjoying the holiday. I wonder if I should tell them the hydroboost is leaking in the cab or see if they find it on their own
2007 XL CC,DRW,4x4.
post #9 of 16 Old 11-20-2012, 06:32 AM
i went through all of this about a year and a half ago, not even worth the trouble going to the dealer and raising hell, cause the dealers dont give a S&%T ! Just go through the truck, make a list and start replacing parts.
lubbock guy is offline
post #10 of 16 Old 11-20-2012, 06:40 AM
Yep, been there too, bought a truck with 5 of 8 injectors being toast, had no idea, first diesel and never drove one. Dealer told me it was just becasue it was cold and nasty out, so I figured just wasn't warm.
Thank goodness Ford replaced them under their 100K warranty, I was at like 98500. It was almost major suck and I most likely would have just traded it before I made a payment on it and ate my $$
Sorry to hear the bad luck, but sounds like the filter was definitely a major cause of some of the other issues.
