Hot shots???? - Ford Powerstroke Diesel Forum
post #1 of 5 Old 11-19-2012, 10:34 AM Thread Starter
Hot shots????
Has anybody used this stuff? Is it as good as they say?
TdubF250 is offline
post #2 of 5 Old 11-19-2012, 10:40 AM
I use it. Engine is smoother and quieter. Cold starts are better. Fuel milage is slightly better.
It works for me and is easy to get now that tractor supply carries it for the same price.
2006 cc 4x4,Rotella 5-40,Amsoil bypass filter Dieselsite coolant filter, edge evolution, K&N air filter, high idle mod, zoodad mod, 60 gallon Titan Tank, blue spring kit, Airlift 5000 bags, Bilstein hd shocks, MBRP 4 inch st pipe turbo back, welded egr cooler
rowcoach is offline
post #3 of 5 Old 11-19-2012, 10:46 AM Thread Starter
When I first put it in she's running worse than ever. Is this normal? Does it go away? I'm confused right now. Very rough between 40-70 mph.
TdubF250 is offline
post #4 of 5 Old 11-19-2012, 11:15 AM
RedneckYankee's Avatar
I tried it to see if I could get an injector to clear up that I thought was having stictation problems. It only bought me some time is all. Ended up having to replace injector #6. However though it has quieted down the injectors some and has helped with cold starts. Read a lot on the stuff and it takes about 1000 miles for it to do its stuff if its gonna help at all. IMOH will it fix a problem no but it may buy you some time.
David
"Hold my beer and watch this"
2005 Excurstion Limited RWD
Sinister EGR Deleate
SCT Tuner MPT Custom Tune Econ/Perf
Dash Boss Monitor
Blue Spring Upgrade
Nitto Terra Grappler 285/75/16
Bilstien 4600 shocks
No Kitty
4" Straight piped
Studded
Updated Stand pipes and Dummy Plugs
1996 F250 XCLB 4x4
4" Ruff Country Lift
Ruff Country N2O Shocks
RedneckYankee is offline
post #5 of 5 Old 11-19-2012, 06:35 PM
Galaxie's Avatar
Hot shot worked for a friend of mine but took a while. RevX seems to work right away for the most part.
Colin
59-68Galaxies, Fairlanes
54 Ford Skyliner Glass Top
60 Country Sedan Wagon
87/93 5.0s 347
Buy/Sell/Trade/Service 40s50s60s cars!
06 F350 Dark Stone XLT FX4
SCTX3 Custom Tunes
ARP Head Studs
EGR Cooler gone
MBRP Stright Pipe
Edge Insight
20" Harleys 35" AT2
2011 Tailgate
Eaton TrueTrac
2" Leveling
Black Windows/lights
Blue Spring
03 Turbo
Galaxie is offline
