What the hell caused this!?! - Ford Powerstroke Diesel Forum
Old 11-19-2012, 09:28 AM
Speedo when out while at the track yesterday, went to replace the sensor today, and found this. I've never been inside a Dana 80, is there any way the abs ring can come loose?
Old 11-19-2012, 01:19 PM
There are quit a few things in the rear end that can come loose, I know i'm not being specific. You should probably pull the cover.
Sent from my phone that somebody didn't help me get.
Old 11-19-2012, 01:22 PM
ya that could be scary
pull the cover asap
Old 11-19-2012, 02:27 PM
Oh yea, I plan on pulling the cover for sure. I just didnt have the time or new gear oil at work today.
What's crazy is, I put the old sensor back in so it wouldn't mess up the new one. And I left it unplugged because the speedometer was jumping around causing the converter to go in and out of lock up, but with it unplugged the speedo works perfect. I guess it has a sensor in the trans also. Of corse I still have an abs light and code.
But I'll pull the cover prolly thi weekend.
Old 11-19-2012, 03:10 PM
As far as I know, the rear sensor is just for abs.
Old 11-19-2012, 03:16 PM
umm no other speed sensor that I was aware of
HMMMM
Old 11-19-2012, 03:17 PM
the fronts are just ABS and the rear is ABS VSS vehicle speed sender from all I ever learned about these
Old 11-19-2012, 03:18 PM
Guess I should ask if u have a manual trans ?
Old 11-19-2012, 03:44 PM
No it's an auto. 03 6.0 drw Dana 80
Old 11-26-2012, 04:34 PM
Update.....the clutches in the possi unit exploded and took out the abs ring. So now I'm trying to figure out if I should get another stock limited slip or a locker.
