BLUE SPRING - Ford Powerstroke Diesel Forum
Old 11-19-2012, 07:49 AM
BLUE SPRING
Y IS IT SO IMPORTANT TO UP GRADE TO THE BLUE SPRING
Old 11-19-2012, 08:01 AM
REALLY!!! Ok i'll bite. Cause low fuel pressure=starved fuel injectors which=$$$ in repair bills.
Old 11-19-2012, 08:07 AM
The original spring tends to weaken over time. The blue spring is an upgraded spring which eliminates low fuel pressure and as Rick said low pressure = big bucks.
Old 11-19-2012, 08:30 AM
ok where is it cause y not i,ll do it thanks
Old 11-19-2012, 08:34 AM
Take a gander at this:
Installing the blue spring kit in the 6.0
Quick search will also bring you other great write ups.
Ford 6.0L "Installing blue spring kit"
Old 11-19-2012, 08:38 AM
Send a message via Skype™ to J HO 22
usually gain about 10psi
Old 11-19-2012, 08:39 AM
This is a link that will show you how to. <CLICK HERE>
Save yourself some money and get your parts from Tousley Ford
Old 11-19-2012, 08:41 AM
i just found that ..yeah when i remove the turbo to clean it i will replace the spring is that a dealer item
Old 11-19-2012, 08:42 AM
Feedback Score: 3 reviews
Updating the blue spring, shouldn't stop a truck owner from installing a Fuel Psi gauge. Just because someone drops in the spring, doesn't guarantees good fuel psi.
Sent from my iPhone using AutoGuide.com App
Old 11-19-2012, 08:44 AM
Yup. I am still planning on getting the FP stuff
