Should I worry about it?? - Ford Powerstroke Diesel Forum
Old 11-18-2012, 10:42 PM
The truck is still new to me, and I have noticed a puff of smoke at start up. The temps have started to fall to 45 Deg. and less. It's just a puff on the cold start, and then its fine after that. Being a diesel Noob, I'm just wondering if I should check anything.
Thanks!
Old 11-18-2012, 11:17 PM
It will be helpful knowing what has been done to the truck. Also what color the smoke is.
Old 11-19-2012, 12:16 AM
Truck has SCT Livewire TS..only running the street canned tune..........stock otherwise. 95,000 miles
Smoke appears gray, maybe a little blue tint
Old 11-19-2012, 02:17 AM
mine gives a little puff like this, it also does it in the summer but its black.
i was told its from a combination of the tuning and the vanes of the turbo not open yet.
Old 11-19-2012, 03:36 AM
You need a monitor to watch battery voltage and ficm voltage.....Write Up: Monitoring the 6.0L PSD.
Do you have a ccv mod?
Sent from my phone that somebody didn't help me get.
Old 11-19-2012, 10:36 AM
Ummm,,,,,,,,,,,I do have a monitor..............The SCT Livewire TS.............Battery voltage drops to around 11volts or so at startup, and the ficm volts never drop below 48.
Old 11-19-2012, 10:55 AM
mine does the same thing...ONLY on cold starts and its black. From what I understand, its perfectly normal
Old 11-19-2012, 11:05 AM
Thanks!...............I'm not too worried about it, but i thought i would ask!
