Tranny Filter - Ford Powerstroke Diesel Forum
Old 11-18-2012, 06:10 PM
Tranny Filter
Anyone know how often the tranny filter located on the front passenger side below the radiator should be replaced and might you have a part#
Old 11-18-2012, 07:14 PM
Scheduled maintenance book says every 30,000 miles (along with a fluid change).
Filter is an FT-145 that you can find at dieselfiltersonline.com
6.0 Liter Turbo Diesel Transmission Filters - Ford 6.0 Liter Turbo Diesel Motorcraft External Transmission Filter - Diesel Filters,Additives,brake rotors, and brake pads for Chevy, Dodge and Ford Diesel Trucks
Lee
Old 11-18-2012, 07:25 PM
Thank you
Old 11-18-2012, 09:10 PM
Buy the NTZ filter, it's the same one. NTZ makes them for Ford.
And the others oil and fuel, Racor.
Old 11-19-2012, 03:48 AM
It is easy enough to do, so I change it every 15k miles.
Old 11-19-2012, 04:20 AM
When you do replace it, suggest you use an air impact to remove it. Using a standard wrench can twist the lines....so I find using the air impact for removal best. However, use a wrench to put it back on so it isn't overtightened.
