got stuck.. - Ford Powerstroke Diesel Forum
post #1 of 15 Old 11-18-2012, 03:21 PM Thread Starter
Metal Mulisha's Avatar
got stuck..
in 4 low I decided to be a show off and take my truck through a hummer corse. all was well until i tried to get out of 4 low and it really didnt want to. I unlocked the hubs and put it back into 2 wheel and drove it around the parking lot but it wouldn't disengage. I couldnt spin the front driveshaft by hand. I drove it home nice and slow and messed with it and it finally came out when I put it in nuetral for the 2nd time. Any idea what caused this? P.S. heres a video of a 6.0 trying to be a hummer
2006 F-250 Lariat
Super Cab short bed
20% tint
20" LED light bar
Diamond eye 5" straight pipe
River City Diesel EGR delete
ARP head studs w/ OEM gaskets
Blue spring
SCT X3 xtreme street
Edge Insight CTS
Mag Hytec diff cover
7 inch Icon lift
20x10 machinedFuel Hostage rims
37x13.50x20 Toyo Open Country M/T
Metal Mulisha is offline
post #2 of 15 Old 11-18-2012, 03:24 PM
Nice...u def got ground clearance...
Sent from my ADR6400L using AutoGuide.Com Free App
-Mike-
2006 F-350 Lariat, Supercab, 6.0L, 3.73's...Rhinolined Bed...6 Spd Handshaker...Mag-Hytec Diff. Covers...Smoked Recon Lights...Amsoil oils front 2 back...Optima Yellow Tops...MBRP 5" ST8 Pipe, Turbo Back...Dieselsite Coolant Filter...Amsoil/Injen CAI...SCT SF3 Canned Tunes 4 Now...CFM Intake Manifold and Boost Tube...Blue Spring Upgrade...Edge Insite CTS !!!
pete37922 is offline
post #3 of 15 Old 11-18-2012, 03:48 PM
I usually have to back up a few feet for it to disengage.
Killerford is offline
post #4 of 15 Old 11-18-2012, 05:12 PM
6.0f250firstcar's Avatar
Where was that?
Ryan
6.0f250firstcar is offline
post #5 of 15 Old 11-18-2012, 05:25 PM
USAFBowman's Avatar
Force your brake all the way to the floor then flip the switch. Mines done that before. For some reason it wasn't reading I was on the brake
Sent from my iPhone using AutoGuide.com Free App
USAFBowman is offline
post #6 of 15 Old 11-18-2012, 05:47 PM Thread Starter
Ill have to try that and the reverse trick. I want to get this sorted out before the snow hits
2006 F-250 Lariat
Super Cab short bed
20% tint
20" LED light bar
Blue spring
Edge Insight CTS
7 inch Icon lift
post #7 of 15 Old 11-18-2012, 05:51 PM
Hightech23435's Avatar
You used 4 low for that?
Hightech23435 is offline
post #8 of 15 Old 11-18-2012, 05:55 PM Thread Starter
I had never even tried 4 low out since I have owned the truck so i figured that was as good of time as any
2006 F-250 Lariat
Super Cab short bed
20% tint
20" LED light bar
Blue spring
Edge Insight CTS
7 inch Icon lift
post #9 of 15 Old 11-18-2012, 06:06 PM
twoicebergs's Avatar
Quoted: 43 Post(s)
Ouch! Hard surface in 4-Low while turning. Your drive train was screaming at you! It was probably a binding issue. It could also be your internal shift mechanism or external shift motor is on the way out as well, but not likely in this case.
Frank
2007 F-250 Lariat Crew. MBM 190/50s,
KC-68 Stage 3 Turbo,
DashBoss/F/P, and a few other goodies
Stiction Problems - Fix it yourself! -
Want to modify your injectors DIY -
Working for Toys
twoicebergs is offline
post #10 of 15 Old 11-18-2012, 06:09 PM
kingranch89's Avatar
is this video still working for everyone? i cant seem to get it to work
never mind got it, pretty cool video
2007 F250 king ranch 6.0 powerstroke
SCT w/ custom tunes from innovative
5" mbrp exhaust
Studded and EGR Deleted
FINALLY SOLD!!!!
on to the next toy
kingranch89 is offline
