"3 cylinder injector 1.1 ohms - Ford Powerstroke Diesel Forum
Old 11-18-2012, 09:20 AM
well just decided to ohm it while it was torn down and found my Number 3 injector at 1.1 ohms on one side and .9 on the other. The 1.1 was on the lower two pins any idea on what I should do.
Old 11-18-2012, 12:28 PM
When it rains it pours also flipped the valve cover over and three of the nuts for the CCV not there serached and still couldn't find them. The only problem i'm having on the truck is a cold start injector sticking i'm guessing it is that one.
Old 11-18-2012, 04:22 PM
could that one injector be a remanufactred one making it a little bit higher and drawing 2 more amps
Old 11-18-2012, 06:13 PM
Are you able to read any codes? New injectors ohm out at .8, ambient.
Sent from my phone that somebody didn't help me get.
Old 11-19-2012, 05:55 AM
No codes before the tear down at all. Hell didn't even get a code when the turbo went out kind if weird I know its suppose to be .8 and there all due for a change soon just don't want to buy 155 till I run the MTW stage oone on stock sticks for a couple of months.
