Can fuel injector & FICM problems cause an Edge Juice to have problems? - Ford Powerstroke Diesel Forum
Old 11-18-2012, 05:37 AM
I had an Edge Juice with Attitude in my truck. It gave me a Boost error on the Edge module as well as an engine light on the truck. I disconnected the Edge and reset my engine light and all was well.
Not long after that I figured out that my FICM had very very low voltage and my truck would hardly start. So I took it out and had it repaired and upgraded to the higher voltage.
My truck still ran rough so I had it checked out by a local diesel specialist. I had 4 bad fuel injectors. I ended up replacing all 8 injectors and now the truck runs perfectly.
My Edge is still disconnected. Does anyone know if it's possible that my fuel problems could have caused the Edge to have problems? I don't know if I should reinstall it and see what happens or send it back to Edge and spend the $100 to have them repair it. Any opinions are appreciated.
Thanks
