anoyher code 0299 - Ford Powerstroke Diesel Forum
post #1 of 2 Old 11-17-2012, 11:04 AM Thread Starter
anoyher code 0299
it comes on every 2 or 3 days and if dont delete it then the lite comes on,, my boost is good but when i start it up in the morning it chatters about 2 times like metal against metal then thats it .if it needs clean about how much of a job is it .thanks
dullybob is offline
post #2 of 2 Old 11-17-2012, 11:36 AM
twoicebergs's Avatar
Quoted: 43 Post(s)
Plan on 1-2 hours plus cleaning time. There are some very good explanations with photos and video links here and on the web. As you may find out, if you do not position it as recommended, it can be a bit difficult to align the vanes and keep the trim plate in the right spot while closing the case.
DTS Articles - Turbocharger Reconditioning
Frank
2007 F-250 Lariat Crew. MBM 190/50s,
KC-68 Stage 3 Turbo,
DashBoss/F/P, and a few other goodies
Stiction Problems - Fix it yourself! -
Want to modify your injectors DIY -
Working for Toys
twoicebergs is offline
