Coolant filter- before or after flush? - Ford Powerstroke Diesel Forum
post #1 of 4 Old 11-17-2012, 07:45 AM Thread Starter
I am heading out of town tomorrow morning and just got my coolant filter. Should I wait to install it after and flush and I go with ELC or should I put it on now. I just don't have time today to do full flush.
Thanks.
Sent from my iPhone using AutoGuide.com Free App
usctrack is offline
post #2 of 4 Old 11-17-2012, 08:44 AM
NJstrokin07's Avatar
put it on right away! run a couple thousand miles before you do the flush to catch as much crap as you can
-Matt
'07 F250
6spd
Edge Evolution CS
3.5" Turbo Back
2.5" Front Coil Spacer, 2" Rear Add a Leaf
Sinister Coolant Filter
Updated Stand Pipes, Dplugs
Updated STC
CCV Mod
Rotella T6
OB Air w/ Air Horn
2 12" 1000w Sony xplod subs
Bulletproof coming soon!!
NJstrokin07 is offline
post #3 of 4 Old 11-17-2012, 02:03 PM
Coolant Filter
Put it on ASAP. I did the same thing; I put it on before a road trip and it gave the filter a chance to continually work on the system while on the trip.
When I swapped my first coolant filter out, the coolant coming out of it looked like chocolate milk. Take an extra filter with you just in case your's gets plugged up before your trip ends. Side note, only hand tighten the filter, run it and check for leaks. If you put in on to tight, it is a pain in the rear to get off.
This will give you a jump start on getting all the crud out before your flush.
2006 Crew Cab XLT 6.0
80, XXX miles
Edge CTS Gauge
Blue spring upgrade
PMM coolant filter
Roland A. is offline
post #4 of 4 Old 11-17-2012, 06:15 PM Thread Starter
Installed it this afternoon. Everything went well. I had my truck plugged in since it was a little cool and I was surprised at how hot the coolant was coming out of the heater core when the truck was cool.
usctrack is offline
