alternator charge - Ford Powerstroke Diesel Forum
Old 11-15-2012, 02:21 PM
alternator charge
I was looking at batteryvoltage with my monitor the other day and it showed 13.1 while idling and 13.2-.3 when driving at 70mph. is this normal. everything operates fine, i just thought you should be seeing closer to 14v?
Old 11-15-2012, 02:44 PM
thats good compared to mine lol. at idle i see 12.2-12.6 and driving i see 12.9-13.4
Old 11-15-2012, 04:48 PM
Really you should, but you are monitoring, so keep a good eye on it. Less than 13v, your batts are going to suffer, imo.
Sent from my phone that somebody didn't help me get.
Old 11-15-2012, 05:20 PM
War is the answer!
You need to get both your batteries and your alternator tested. They should not be that low.
Sent from my SPH-L710 using AutoGuide.Com Free App
Old 11-15-2012, 06:11 PM
mine like that to but when you check it at the batteries its almost a volt higher. Mines about 13.1 with the cts and at the batteries its 13.9-14.2, try that
Old 11-15-2012, 06:52 PM
OK, thanks for all the input.
Battery's are new, well bought around Feb or march. Alternator was replaced about the same time.
Batts tested good on a load tester. Havent tested the alternator yet though. But like I said, no battery light or anything out of the ordinary. Operates like normal.
Old 11-15-2012, 07:08 PM
Mine is the same way. Monitor shows 13.2, at batteries 14.1 checked with a good quality meter.
Old 11-16-2012, 03:21 AM
War is the answer!
Did you replace out with a new alternator or a reman? Check your cables.
