Hey guys, did my EGR delte over the weekend, and of course I get the p0401 and the p1000 codes. But yesterday and today I got a new code which is a P0671 code. I am not getting hit on any other cylinders for the glow plugs. Possibly just a bad plug? What do yall recommend?
Think I saw people were testing ohms on it.
Hey guys finally got around to that glow plug. Pulled it out and it ended up having oil coating it. And the end with the 10mm hex bead also had oil. I took some pics to see what you guys think and see what you guys think might be going on.
![]() [IMG] [/IMG][IMG] [/IMG][IMG] [/IMG]Sent from my iPhone using AutoGuide.com App Last edited by frakchered; 11-25-2012 at 08:06 AM. |
Is it common to see a little oil seepage from the aluminum piece and the head? I don't have any signs of other issues going on.
Test it. Less than 1 ohm it should be good (0.8 new). If it tests good, wire trace check back to the GP module.
