Motorcraft vs. Stant degas cap - Ford Powerstroke Diesel Forum
Old 11-15-2012, 06:22 AM
So my degas bottle puked for the first time yesterday. After some reading I found that I have the old outdated cap with the white sticker on it.
After some searching it seems that there are two options for caps, the updated Ford motorcraft part and the stant cap from the local parts stores.
After reading good and bad about both, which do you prefer?
Old 11-15-2012, 06:54 AM
for these engines i would always go with motor craft
I have the stant and will always use that cap... I check for holding pressure all the time and they hold perfect . I've had the motorcraft and had nothing but problems. Had a stant on the truck now for 160k miles
Old 11-15-2012, 06:58 AM
I have the updated OEM and have had no issues
Old 11-15-2012, 07:55 AM
I have the auto value one from Bumper to Bumper, works just fine.
Old 11-15-2012, 08:35 AM
Running with stant caps since last year in both of my trucks and NO PROBLEMS so far.
Old 11-15-2012, 08:53 AM
Feedback Score: 3 reviews
And what is the blow off psi on the Stant?
Sent from my iPhone using AutoGuide.com App
Old 11-15-2012, 09:07 AM
Yea i wouldn't be to worried about what cap you use as long as it blows at 16 psi and has the updated spring than its fine.
Old 11-15-2012, 10:21 AM
How can you tell??
Old 11-15-2012, 10:35 AM
Only reason I would be leaning towards Motorcraft is because I heard the Stant one doesn't click when it is tightened down all the way and I don't want to over tighten it.
I have heard great things about the Stant over Motorcraft though.
