Need Help bad guys!! - Ford Powerstroke Diesel Forum
post #1 of 5 Old 11-14-2012, 04:18 PM Thread Starter
Powerhead357mag's Avatar
Exclamation Need Help bad guys!!
03 6.0. battery has intermittent charging while driving ive put a new alternator on and had that one tested twice. 2 new batteries and it still does it. ive checked all the wiring as far as i can and have put a battery cable from the atl post to the battery terminal and also from the neg battery terminal to the engine and neither helped. when its not charging if you jump from the battery to the green/red wire on the alt harness it starts charging. the truck HAS to get me to work tomorrow at the nuke plant over 25 miles away please help ASAP!!!
Thank you,
Tim
772-216-5640
Powerhead357mag is offline
post #2 of 5 Old 11-14-2012, 05:53 PM
double check your ground wires probally a internally broke one. thats all I can think of
03 f-250
blue spring
4inch turbo back exhaust
egr delete
MTW HYBRID
SCT livewire
scan gauge w egt
zoodad mod
fuel press gauge
225,000 miles
155/stock holder diesel
tatertot is offline
post #3 of 5 Old 11-15-2012, 05:51 AM Thread Starter
I've put extra ground wires on the block and that did not help. Any other ideas guys?
Thanks,
Tim
post #4 of 5 Old 11-15-2012, 07:13 AM
I have a similar issue. Occasionally my battyer light on my dash comes on at first startup. Two new batteries and a new alternator, still does it occasionally.
Does it less with a lil ATF in the fuel tank, lol, j/k.
niftytwofifty is offline
post #5 of 5 Old 11-15-2012, 07:28 AM
10secondC's Avatar
Thank you,
Tim
772-216-5640
The exciter wire is interrupted somewhere....you proved that by touching the battery to it and it starts charging. Time to find a wiring schematic and trace it back.
2007 XL CC,DRW,4x4.
When I die I wanna go peacefully in my sleep like my Grandpa, not screaming in terror like the passengers in his car.
10secondC is offline
