Going to be pulling heavy load
Okay I am going to be making a 700 mile trip from Eily nv to florence arizona pulling a 29ft fifth wheel trailer with a 92 Chevy s10 hook to the trailer. I have a 06 ford f250 with the 6.0 my oil temps are already running at about 6-7 degree warmer than engine coolant temp. The engine is bone stock the only mode done is the crank case breather mode is all I have done what do u guys think about making that long of a trip with the way the temps are running thanks everyone for the in put
6 to 7 delta T is well within normal operating range i wouldnt worry about it at all. It sounds like you have a monitor already so just monitor your temps as you should be always and go for it. If you dont have a monitor GET ONE
Yep just bought the dash boss and love it my temps run like that empty and pulling what would u guys call red line temp for the oil cooler so I can monitor that to make sure I don't blow up the oil cooler. Just flushed my cooling system I flushed is so good that I have 5 5 gallon bucket of old coolant I have to find a home for lol put in cat coolant back in and she is doing good so far. One other question what temp is red line for the trany as well so I can set all my limits up so I save my truck on this pull
Are you running conv or syn oil, tranny temp shouldnt go much above 220 for long periods IMO
Here is what i have my alarms set at, some are set to a point below "Red Line" just so i know when i am getting close and need to pay attention. EGT- 1200 EOT- 230 ECT- 220 ETT- 220 |
I am running rotela 15/40 I go from synth to normal every other oil change thank for the temp I don't have exh gas temp is all
You know how they say not to change the type of food you feed your pets, well IMO engine oil is the same... Choose one and stick to it! I am running Rotella T-6 full Syn oil. I switched from Dyno 15-40 and noticed it run Alot better
Are you tuned? If not I would not worry about your EGT too much... Just don't run up mountains at full throttle. |
Those are the numbers I go by When towing
If your running a stock tune then Egt's shouldnt be an issue either. That being said i would highly reccomend you monitor them none the less, the probe is a pretty easy install. If you have Syn oil in it you can hit 240 for again a short time some have gone as high as 250 but i try to never go much above 230 for any length of time and if i get close to 240 i back off. But that is just me and my habits, others will run there truck harder with no problems. For what reason do you alternate oils? I would reccomend just sticking with Syn i run T-6 5w40 all year and love it
I plan on taking my time on my way back and going to drive at night to make it just alittle bit easier on the truck and cooling system I cruise at about 55 to 60 when pulling going to start running synthic next oil change and yes truck has no tune right now thanks everyone
