Shaking & shuddering - bad injector?
I have a 2005 F-350 with 210000km (135k miles) and this morning the minute she fired up I knew something was wrong. I had an important road trip planned which I couldn't cancel, so I drove 200+ miles today. Rough idle, shaking and shuddering when lugging below 2000rpm. If I'm cruising at 1500 rpm and try and gently step on it, the whole truck just shakes. Tow/haul helped a bit. Above 2000rpm it's not too bad.
I have a Scangauge and there are no codes, FICM is freshly rebuilt by Ed and voltage is 13.5, sometimes it drops to 13 and once in a while briefly to 12.5. The truck is stock except for a 40hp FICM tune, and EGR delete. Have I lost an injector? Without throwing a code? |
What you describe is what happened when I lost an injector, but I had two codes. Check your ficm and injector connectors.
Sent from my phone that somebody didn't help me get. |
I thought ficm voltage is suppose to be 48v??
I'm assuming he is calling out the logic voltage, I shouldn't assume I guess. Good point. Op have you checked the injector voltages?
The main ficm voltage is 48. All the x-gauges I have programmed in my Scangauge seem to be within range. I haven't checked the individual injector voltages, I assume that requires a bit of reprogramming to my Scanguage?
I have another short road trip to do in the morning, will I cause any further damage if I drive it 100 miles like this? |
I was talking about the 48v, you probably have an injector that is not fueling. If it was overfueling, it is not good to run it like that. I hated running mine, it wasn't fueling, I consider that lack of lubrication.
Oil change and fuel filters tomorrow........
So I dropped by the shop and had them read the codes. Why didn't my Scangauge give me these? It said no codes found, did I set it up wrong?
PO265 Injector circuit high cylinder 2 PO266 Camshaft postion sensor circuit range performance Thoughts? |
As for the camshaft sensor code.....it may be from the irratic running. Sent from my phone that somebody didn't help me get. |
the symptons you describe are almost exactly what I had when I lost my injector #5, My check engine light did come on and the scangauge did read the code. I would check the wiring closely, I found on mine that the insulation was worn through. I resoldered the wire and insulated the whole thing really well, but my injector was still out (not sure if the wire issue caused the injector to fail).
When I ohmed out the coils on my injector, one of the coils was way out of wack, I replaced the injector and that problem cleared up. |
