My RAZR made me send this... |
If you want to check the hgs make a pressure guage and hook it up to the degas bottle. I bought 10 foot of 3/4 heater hose ,a three way, and a Low pressure gauge. Cost was under 25.00. If you read more then 16 psi the hgs are probably done. That's how I knew mine were gone. I've read around 5-8 psi is good.
Sent from my phone that somebody didn't help me get. |
I dont ever see smoke but I do see vapors even out of the oil fill when I take the cap off. I get a bit of oil mist spray onto my degas bottle from the dip stick.
Sent from my SPH-L710 using AutoGuide.Com Free App |
I doubt its about to go.... Relax. Its oil and diffent things can play here. Temp out side, moisture, etc. If you have TONS OF SMOKE, yea, not good. A little.... wouldnt strees Make sure everything is set up correctly.
Wait a minute.. I think there is some people getting scared by how much "blow by" you can have... In ANY engine, take the oil cap off while running and you will see a little little bit of smoke/vapor coming out. Its combustion/heat in that engine what do you think your going to see lol Anyways a little smoke is NORMAL- that being said if it looks like a freight train smoking then you have a problem and if it does chances are it will run poorly. I think we all worry to much about certain "problems" we may have? If your not burning up oil, meaning oil level is at right level, coolant stays full- Your engine is fine.
Here you go........https://www.youtube.com/watch?v=jscf...e_gdata_player
